2009+ Nissan GT-R Nissan R35 GT-R Discussion
First E85-Tuned R35 GTR makes BIG POWER!!!
Old Jan 25, 2010 | 01:48 PM
UMW350Z's Avatar
UMW350Z
Originally Posted by rcdash
I'm sensitive to fuel vapor odor and I think E85 exhaust emissions smell a whole heck of a lot better based on my brief experience with Joe K's car at ZdayZ.
Nice post Tim@Cobb!
Not like I want to sniff the tailpipes, just curious if it smelled like a bottle of vodka, popcorn, or my old college house's basement after a party
Old Jan 26, 2010 | 06:29 AM
saqib55's Avatar
saqib55
very informative posts guys!
My question is, if you are using one tank for gasoline and e85, how will the overall system change its tune to work with the specific octane that will result from mixing gasoline and e85. One video that i saw used a ProEFI to accommodate this. Heres the video actually:
http://www.youtube.com/watch?v=a1CzmmMUy50
Old Jan 27, 2010 | 09:12 AM
COBB Tuning's Avatar
COBB Tuning
Vendor - Former Vendor
We aren't changing fuel tanks or using two fuel tanks, it's the single OEM fuel tank. To switch between fuel grades you must empty the tank and then fill your tank with the desired fuel. Then with your AccessPORT, change your tune to the appropriate map for whatever fuel you dumped in. Of course you will never get 100% of the fuel out of the tank so there is some mixing, but as long as you run your car down to almost empty and then fill it, we have not seen any detrimental effects to SLIGHT mixing. However, mixing 1/4 tank of E85 gasoline, would be too much etc. Basically, there is no fuel sensor like there would be on true flex fuel cars. It's like changing between pump fuel and C16, You wouldn't want to run your C16 map on a pump/C16 mix and visa versa.
Travis
COBB Tuning
Old Jan 27, 2010 | 05:03 PM
miloz31's Avatar
miloz31
Are you guys using stock fuel filters on the E85 setup?
Old Feb 1, 2010 | 02:03 PM
COBB Tuning
It smells a lot like cheap burbon!
Yes we are using the stock filter socks.
Old Feb 1, 2010 | 02:11 PM
kennedy's Avatar
kennedy
Cobb not trying to bring your competitor up but with up-rev do you think it would be feasible to have one map for e85 and one for pump gas? Also do you think I would notice much gain with e85 on a NA bolt on Hr car? I was considering it awhile ago but not sure just would like your input.
Old Feb 2, 2010 | 03:31 AM
specialized5223's Avatar
specialized5223
subscribing
Old Feb 2, 2010 | 07:24 AM
Rommy's Avatar
Rommy
Very nice. Now slap on some bigger injectors, bigger piping, more boost, and you'll either have:
a. 800HP
b. Blown turbos
c. Blown engine
d. All of the above
Hopefully just 'A' though.
Old Feb 2, 2010 | 07:41 AM
str8dum1's Avatar
str8dum1
he already told you, yes but you 'll need to drain your tank between swapping fuels.....
Old Feb 14, 2010 | 06:41 AM
kennedy's Avatar
kennedy
I understood the part of draining the tank when swapping but did he answer the other question no he didn't. Thanks for coming out.
Old Feb 15, 2010 | 09:06 AM
COBB Tuning
Will you make more power? Maybe. It all depends on your setup and your tuner. The problem with any NA engine is increasing airflow, so unless you are drastically increasing VE with cams and high-compression pistons etc. There isn't much point to increasing octane if peak power is what you are after. That said, this isn't something we have done any testing on, so I am just theorizing. Perhaps if you were to add in lots of ignition advance you might see some gains with the higher-octane fuel.
Old Feb 15, 2010 | 08:31 PM
kennedy's Avatar
kennedy
Thanks guys. I am looking at selling the Z and going to the bmw 335i route might look at the e85 route there. This thread was very informative thanks for answering my questions though.
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
