Cold as hell........feel's like winter
Old Dec 26, 2004 | 03:26 AM
zbrid's Avatar
zbrid
Default Cold as hell........feel's like winter
I got my 05 350zr in early November, I only have 300 mi. on it.
now I got it up for the winter. I been starting it up about every two weeks to keep it well lubricated since I have so little miles on it. I let it run for about 30 minutes.
Do you guy's think this is efficient enough?
Old Dec 26, 2004 | 10:35 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
If there's no snow outside take it for a ride! Just wear a lot of jackets. LOL
Old Dec 26, 2004 | 01:16 PM
zbrid's Avatar
zbrid
I wish could take it for ride! But there is about 1' of snow out there,& up here they salt the Road's
Old Dec 27, 2004 | 03:09 AM
ttsupra94's Avatar
ttsupra94
It is pretty cold here too, although i'm sure not as cold as where you are. I still try and drive mine as long as there is no snow or ice on the ground. Took it out this weekend when it was in the 20's. I just make sure to let it warm up.
I usually drive my parents F250 turbo diesel and I have a hard time getting that thing started at 5 in the morning. Finally decided to buy an engine block heater which I will try out tonight.
I didn't think idling was all that great to do. Especially for 30 minutes but i'm no expert.
Old Dec 27, 2004 | 02:20 PM
ohw's Avatar
ohw
I would not idle a new engine for 1/2 hour every 2 weeks for 4 months, too much run time in one RPM. You want to run a new engine in different RPM ranges as much as possible during the break-in period.
If you want to run a broken-in engine every once awhile, just run it till it reaches normal operating temperature to get rid of the moisture in the exhaust system. It should take less than 1/2 hour, may be 10 minutes?
My ZR is covered up in the garage like yours. I choose not to start the car at all during the 3-4 months winter because most of the engine wear is created during startup. The oil was changed before the storage and a trickle charger is connected to the battery to keep it fully charged.
lapham3
Oct 7, 2022 03:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
Mattg350z
Oct 2, 2015 06:51 AM
