Soft Top Gap
Old Feb 17, 2005 | 08:48 PM
Me350Z's Avatar
Me350Z
Default Soft Top Gap
When you guys put your soft top up, is there a 1/2 inch gap between the soft top and the body of the car, behind the wind deflector?
I look back when it's closed and it doesn't seem like it's completely sealed tightly. I'm not sure if it's normal but I don't get any water dripping in.
Old Feb 17, 2005 | 11:03 PM
boldenmd's Avatar
boldenmd
Default Re: Soft Top Gap
No gap. Perhaps you should post pics (and/or run by the dealership to compare what you're talking about).
Old Feb 18, 2005 | 07:10 AM
maxpowers's Avatar
maxpowers
If it doesn't seal tight then there is somthing wrong. There is a thin tape strip between the paint and the top that acts as a gasket.
Old Feb 18, 2005 | 09:44 AM
Ivey's Avatar
Ivey
are you refering to the gap you see when sitting inside the car with the top up and you look back at the black plastic cover behind the deflector? If so, that plastic piece should not be touching the car itself and there is a gap, about 1/2 inch seems right. I'm not sure what the design thought was behind that idea (other than saving the paint) but that's normal for every roadster I have seen.
Hope that helps.
Old Feb 20, 2005 | 09:26 AM
Me350Z's Avatar
Me350Z
Hope that helps.
Yeah, that was what I was referring to. There is a 1/2 inch gap. I guess it is normal. But I'll still go to the dealers and check out another Roadster for my conscience.
Thanks for the info.
Old Feb 20, 2005 | 10:09 AM
Dave Buswell's Avatar
Dave Buswell
I had the same concern when I bought my ZR. I took it to the dealer and he assured me the space was there on purpose (so as not to mar the finish). I will agree with you that it sure doesn't look as thought it belongs.
Old May 21, 2020 | 07:23 AM
Cartel's Avatar
Cartel
Unhappy
I just was noticing mine too here is a picture so everyone knows what is ok or maybe an issue.
Is that rust?? I see this on the under egde of the trunk lid too, like a 3m clear thing??
350Z_Al
Oct 29, 2020 07:44 PM
35reilly
Sep 28, 2015 07:42 AM
