V1 Display in Mirror: Mission Roadster
Old Feb 27, 2006 | 10:38 AM
lamaz's Avatar
lamaz
Lightbulb V1 Display in Mirror: Mission Roadster
This thread will be an extension of the following thread:
https://my350z.com/forum/audio-and-video/103962-v1-install-display-in-mirror.html
OK, once you have read above. Let's get into details. How could or where would we mount the V1 unit in a roadster to have the external display integrated into the mirror? On the coupe they have it somewhat above the rear strut brace almost where the rear glass reaches the roof.
I know we have some creative Roadster owners. 1000's of minds are better than one. Let's focus people.
-LamaZ
These mirrors are hand made by our very own 350Z member/owner "SunsetZ33"
http://www.piddles.net/mirror.htm
Old Feb 27, 2006 | 11:25 AM
BamBam's Avatar
BamBam
I have seen this setup before. I am doing something similar for my A/F gauge.
Are you trying to make the V1 invisible to the police (i.e. is it legal for you to use radar.)?
Could you mount this on a visor or snug it on the dash between the windshield and the gauge pod? I am assuming you are trying to make this as invisible as possible and have a clean look correct? I am not familiar with the V1 does it have remote sensors or is the box the main sensor and needs to be in the line of sight for the detector to work properly?
Old Feb 27, 2006 | 03:20 PM
lamaz's Avatar
lamaz
The V1 isn't illegal in NY, but I might consider moving to VA/MD/DC area where VA and DC have a ban on Radar. I just think this setup is the coolest thing since sliced bread (sliced bread IS incredible).
The problem with your proposal is that the V1 doesn't have remote sensor modules, hence if the rear is out of site then the V1 isn't going to provide very good rear protection. Those who have been to jail know how important it is to have top notch rear protection.
Right now I have the custom mounting bracket setup from MIKE3348. Now given the circumstances, IMO this is the cleanest setup for a Roadster where stealth is not important.
OK, so our first suggestion is on the dash close to the gauge cluster. Anybody else have something creative?
-LamaZ
Old Mar 3, 2006 | 07:37 PM
TheProfessional's Avatar
TheProfessional
I was considering removing my 3rd pod gauge (electric) and adding it in there.
Old Mar 4, 2006 | 05:29 AM
lamaz's Avatar
lamaz
You mean the actual V1 unit in their? Now that is one I would have never thought of myself. Isn't that pretty involved?
I'm guessing you would have to remove the interal components of the V1 and take the whole dash appart to get at the inside of those pod gauges.
All I can say is wow.
-LamaZ
Old Mar 4, 2006 | 01:08 PM
TheProfessional
-LamaZ
Not the V1 but the remote display. All I would need to do is gut the cluster and secure the display. I want the display as close to the computer speedo as possible.
Old Mar 4, 2006 | 01:17 PM
lamaz's Avatar
lamaz
OK, then we get back to the original question..."where to put the V1 unit?" (I'm guessing by your setup, smack below the mirror)
-LamaZ
Old Mar 4, 2006 | 01:18 PM
SmokyTyrz's Avatar
SmokyTyrz
I have Greg's V1 mirror install (thanks Greg!) and I love it. Of course, I have a coupe so I'm not going to be much help in specifics.
I can say though that in my research I saw LOTS of the BMW guys (who can simply buy one of these mirrors as an option) mount the V1 inside the roof, or inside a cubby. If there isn't a lot of material between the V1 and the airspace, and nothing between it is metal or more than a few inches thick, then the performance degradation should only be at the absolute limits of the range. Otherwise the V1 seems to be powerful enough to be completely concealed.
I had thought of mounting it where the sunglass cup is. I think that would work in a coupe. But in a vert I agree it will be tougher.
I have heard of folks taking the V1 out of it's case and cannibalising it into a front and rear remote mounted unit. You've got some cahoneys on you do to do that though!
Good luck
Smoky
Old Mar 4, 2006 | 01:20 PM
TheProfessional
-LamaZ
ACUTALLY... I was going to cut my stock base mirror with a small hole for the rear sensor on the right side. The V1 would mount in front of the mirror, below the stock window dots. It would be out of the way and effective.
Old Mar 4, 2006 | 01:31 PM
lamaz's Avatar
lamaz
(in a yoda voice) "Most impressive"
I've given up on the idea and will simply go with MIKE3348's custom mount.
-LamaZ
Workshop12
Mar 23, 2020 01:45 PM
Tochigi_236
Sep 27, 2015 03:40 PM
