Applying Protectant to top
Old Feb 10, 2008 | 03:16 PM
ZR_Yancy's Avatar
ZR_Yancy
Default Applying Protectant to top
I just applied 303 on my top for the 2nd time in 2 months. I just spray it on but it gets all over the car. Is there a less messy way to apply? I was thinking of applying it to a rag or sponge & wiping it on the top which will get rid of overspray. How long do you let it sit before wiping excess off?
Old Feb 10, 2008 | 03:21 PM
SuperBlack350z's Avatar
SuperBlack350z
yeah, you are suppose to spray it on a rag in the first place. I let it sit for at least a day before driving again.
Old Feb 10, 2008 | 04:38 PM
dhwang80's Avatar
dhwang80
i got one of those velcro grabbers attached to a microfiber sponge disc you can get at wal-mart or any advance auto.
you don't need to super saturate the top with it. spray on cloth--> gently apply --> soak up any excess with a microfiber towel.
voila!
Old Feb 16, 2008 | 09:32 AM
ohw's Avatar
ohw
I use a new paint brush and "paint" the top with the proctectant.
Old Feb 17, 2008 | 07:36 PM
Sunset350ZR's Avatar
Sunset350ZR
What exactly is this protectant?
Old Feb 17, 2008 | 10:56 PM
SuperBlack350z
303 Aerospace vinyl protectant
Old Feb 18, 2008 | 08:15 AM
Sunset350ZR
I realize it is a protectant but is the purpose to be water resistant, dirt resistant ect.
Old Feb 18, 2008 | 08:42 AM
swing2hard's Avatar
swing2hard
where did you get the 303 at? schucks maybe?
Old Feb 18, 2008 | 12:35 PM
ZR_Yancy's Avatar
ZR_Yancy
303 is THE LEADER in UV screening technology and 303 Protectant really is like "SPF 40 Sunscreen ... For Your Stuff." Regular use of 303 Aerospace Protectant can reduce UV caused slow-fade by up to 100%. No other protectant beautifies as intensely, protects as powerfully or lasts as long.
The World's Most Manufacturer-Recommended product: Because of its enduring cosmetic properties, resistance to dust, soiling, and staining, water repellency and unparalleled protective abilities, manufacturers worldwide recommend 303 Aerospace Protectant for countless uses:
Use on Rubber: Latex, Neoprene, EPDM Seals, weather-stripping, Wet/dry suits, rubber roofs, Vinyl, Hypalon, Urethane Vinyl awnings, clear vinyl, convertible tops, tonneaus, car bras, spa covers, pool covers, inflatable boats and so much more !
http://www.303products.com/shop303/i...TOKEN=99968218
Old Feb 18, 2008 | 12:37 PM
ZR_Yancy's Avatar
ZR_Yancy
I order mine online from their website. You can also find them in auto/marine stores.
Old Mar 16, 2008 | 05:39 PM
mycoplasma1's Avatar
mycoplasma1
Kind of on the same subject of keeping your tops clean: I use a lint roller, the same kind you use on your clothes, about once a week, or more often as desired. It's basically masking tape on a spindle. I just roll it over the top, and it picks up any loose dirt or dust that may have settled on the top. It does a great job, and does not leave any sticky residue. I picked up this little trick from the guys that detail cars for the Pebble Beach Concours d elegance. They use the lint rollers on million dollar cars that are drop tops or have cloth tops.
Old Mar 16, 2008 | 06:51 PM
Sunset350ZR
I do this as well but didn't know it was a common practice.
Old Mar 17, 2008 | 03:33 AM
dhwang80's Avatar
dhwang80
does the 303 aerospace protectant bead up water for you all?
i've noticed it doesn't bead up on mine very well, but then again it hasn't rained till 2-3 weeks after the application.
thinking about switching to raggtop to see how it fares?
Old Mar 17, 2008 | 08:49 AM
chickenputo's Avatar
chickenputo
are the sponges good enough to use on the top? or is the spray bottle the better buy?
Old Mar 18, 2008 | 09:08 AM
maxpowers's Avatar
maxpowers
I like 303 better than raggtop (the first product I bought). I find the water to bead longer. Plus, 303 costs a quarter of what raggtop costs.
Old Mar 18, 2008 | 10:10 AM
chickenputo
Just ordered the convertible top kit from 303... and I plan on using a lint roller as well... hopefully I can prolong the life of my top seeing as how I just bought a new one
Old Mar 18, 2008 | 10:20 AM
kenpo_350Z's Avatar
kenpo_350Z
Does it make the top look more black or is just a protectant?
Old Mar 18, 2008 | 11:55 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
FYI ... Our 350Z roadsters DO NOT have cloth tops.
For anyone buying the 303 Protectant make sure you get the VINYL protectant.
Old Mar 18, 2008 | 11:56 AM
dutchboy350Z
Finally some go
Yes.
Old Mar 18, 2008 | 11:58 AM
dutchboy350Z
Finally some go
Think of it as a clear coat for your top. It makes your top look more vibrant.
