Tire Growl
Old Oct 25, 2008 | 05:01 PM
rbc417's Avatar
rbc417
Default Tire Growl
Have now had my 04 350 for almost a year now and I am having tire growl which I have read about the recall and TCB's on this subject. Can anyone tell me how to get rid of this (different tires, correct specs on alignment and if so is there a related TSB on the alignment specs and are all dealers on board with this)
Thanks,
Randy
Old Oct 25, 2008 | 05:25 PM
Not sure why this is posted in the roaster forum. Not a unique roadster problem. Read the feathering thread. Hundreds of comments and potential solutions.
Old Oct 26, 2008 | 08:40 AM
WhiskeyHotel's Avatar
WhiskeyHotel
Tire growl may or may not be related to "feathering." The growl that happens under braking I began to hear on the OEM tires at about 20K miles. The tires were not feathered. They looked fine - maybe a bit of uneven wear. My alignment was fine. It's apparently due to a certain wear pattern on the tires and suspension resonances, etc.
Solutions - buy new tires or rotate the fronts side to side for a try at a getting a bit more use out of the tires.
Old Oct 28, 2008 | 03:31 PM
rbc417's Avatar
rbc417
Thanks for responding.
Old Oct 28, 2008 | 03:41 PM
Built2shredZ's Avatar
Built2shredZ
Throw a Nismo Suspension kit on your car, should take care of all your feathering issues
Old Oct 28, 2008 | 04:21 PM
E.F. VaBeach's Avatar
E.F. VaBeach
Front end alignment is everything. If you have the stock RE40's, get rid of them, they're junk. I went with BFG KDW F1's and they've been flawless for 15K miles. Maybe it's the unusual tread pattern, but it solved the problem.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
