At wits end
Old Oct 13, 2008 | 09:32 PM
mark strauss's Avatar
mark strauss
Default At wits end
I have taken my 2004 Roadster to the dealer 8 times because the "Service Engine" light keeps coming on. The car runs rough and seems to be missing while I am on the freeway. Every time I have brought it in the Service Manager tells me that they cannot find the cause of the problem. I am told that Nissan USA will not replace any parts unless they are shown to be defective or broken. The car is still under warranty. Does anyone have any suggestions. I have spoken with the owner, Peter Mossy, and have contacted Nissan USA. My next step is the BBB and the Consumers Affair Department of California.
Old Oct 13, 2008 | 09:43 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
What mods do you have on your car? What year/model is it? Have you taken it to another dealership?
Make sure they are putting the car on the Consult I or II to make sure the codes are taken from the computer. This code tells them why the light comes on.
Sounds strange that this dealership can't tell you why the light is coming on. Perhaps the O2 sensor is bad.
Old Oct 14, 2008 | 01:27 AM
Phreakdout's Avatar
Phreakdout
That doesn't make sense why the dealer can't find the issue. Are they even trying? If the light comes on then a code must have been thrown. Period. So what code is it?
Does the car get restricted to less than 2500 RPM? If so, the ECU has moved to fail safe mode and it is cutting your fuel. (Stop driving it and get it to the dealer. Perhaps another dealer.)
Shezzzhot is absolutely correct. This needs to be checked by Consult II. See this for the procedures and a list of codes.
http://www.myzroadster.com/files/200...0manual/ec.pdf
Old Oct 29, 2008 | 04:38 PM
yogipower's Avatar
yogipower
Try to fill up the gas all the way. I had the same problem as you but mine was "Air in the oil tank". Hope your Z turn out good and good luck. One last thing "Do not trying to fight with Nissan Dealership"... you will not get nothing from them but waste time.
Pleask
Dec 21, 2021 03:17 PM
apex locator
Jul 23, 2021 02:27 AM
pr_350z
Oct 1, 2015 05:03 PM
Depravity
Oct 1, 2015 04:49 PM
cashmoney03
Sep 27, 2015 05:24 PM
