Advise needed!!! top only goes down 4/5s of the way
Old Jan 23, 2009 | 01:41 PM
fran914's Avatar
fran914
Default Advise needed!!! top only goes down 4/5s of the way
concerned if somethings wrong but it was about 45 degrees today
so just wanted to now if i should be worried and if yes then could it be replaced by warranty.
Old Jan 23, 2009 | 01:47 PM
iStan's Avatar
iStan
ZR
Mine does the same thing in the cold.
Old Jan 23, 2009 | 07:27 PM
johns350's Avatar
johns350
Ditto. Less than @55 degrees......usually takes 2 or 3 times, but it will work. Above that temp - it works well.
Old Jan 23, 2009 | 07:52 PM
Flick Montana's Avatar
Flick Montana
Mine did that as well. It wasn't when it was cold though. I'm trying for the life of me to remember if I did something to correct it or if it just went away, but I really can't remember. I want to say something was blocking it in the area where it is stored and it was getting jammed.
Old Jan 24, 2009 | 11:52 AM
richcity's Avatar
richcity
Same here
Old Jan 24, 2009 | 04:30 PM
CaliBoy's Avatar
CaliBoy
never had that problem even in 39 degrees in big bear...strange.
Old Jan 24, 2009 | 07:15 PM
Flick Montana
I never had that problem even when I stored my car outside in Indiana winters. It sounds fairly common though, so I guess I'll just count myself lucky.
Old Jan 24, 2009 | 07:38 PM
Ontheroad's Avatar
Ontheroad
I test drove an '05 last week and it wouldn't open quite all the way. It was a very cold day. The service tech at the dealer said it's good to grease the hinge joints (I think that's what he called them) at least once per year. After he did that it opened and closed without a hitch. Maybe some WD-40 in the right spot will do the trick.
--DAN
Old Jan 24, 2009 | 08:45 PM
dlbomber1's Avatar
dlbomber1
When they demo'd my car to me it was quite funny it did it then and they panic'd until the experienced tech came out shut my passenger door and said ok now try it. Apparently the mechanism has multiple locking points for example the passenger seat. The other is the doors have to be set also along with the windows which is why they roll up before you see it moves. Its worked flawlessly for me since I made sure those points were done along with keepin pressure on the brake. Or then again could this be coincidence too? lol you never know theres alot of people who said its happened to them too, but try this out see if this helps.
Old Jan 25, 2009 | 07:41 PM
dsmZ's Avatar
dsmZ
Default looking like this?
After I got rear-ended it started happening to me, but I didn't see anything in the way. I push on it a little and it worked fine for 4-5 days then started again. Is this what its looking like?
Attached Thumbnails Advise needed!!! top only goes down 4/5s of the way-img_0472.jpg
Old Jan 25, 2009 | 08:06 PM
fran914's Avatar
fran914
Default yea exactly like that
yea and i tried pushing down on it a little and it worked after making a really loud clicking sound lol but yea that picture makes me want to pull my hair haha
Old Jan 25, 2009 | 08:19 PM
johns350's Avatar
johns350
I never pushed it - but once it did make a loud 'click' or something like that - then go down. I really sounded like two parts of the mechanism were coming into contact - it pushed past - then it went all the way down.
Again - in warm weather - it works 100% of the time on the first try (for me).
Old Jan 25, 2009 | 08:30 PM
dsmZ's Avatar
dsmZ
^^ also had the clicks... im in FL so i dont know why mine is getting jammed, although it DID only happen when it got cold. ill see what happens tomorrow if its 60+ ill give it a whirl
Old Jan 25, 2009 | 08:50 PM
KombatKing's Avatar
KombatKing
Hope your motors aren't going out...
My roof did that a few times BEFORE I had all the motors replaced, but it can also stop like that if it's too cold also because the roof material is stiffer and won't stack like it needs to.
~KK
Old Jan 25, 2009 | 08:56 PM
Phantom Menace's Avatar
Phantom Menace
Give her more alcohol!
Old Jan 26, 2009 | 01:35 PM
dsmZ's Avatar
dsmZ
temp= 67
results= top went down....
guess it IS just because of the cold... thats interesting to know
Old Jan 26, 2009 | 07:40 PM
johns350's Avatar
johns350
Old Jan 27, 2009 | 10:28 AM
CRJ700's Avatar
CRJ700
I don't have my owners manual in front of me but I think there is a note to the effect that it is not recommended to operate the top below 45 degrees F.
Old Jan 27, 2009 | 11:09 AM
Rayysmans's Avatar
Rayysmans
The Nissan Owner's Manual "Caution"
*Do not operate the top when the temperatur is below 32 F..(0 C). this may result in damage to the top material or operating system.
*Do not open the top when t is wet or damp. this may cause interior water damage stains or mildew on the top material
*Be sure to turn off the rear window defroster switch. Never turn it on while the top is being operated or fully opened. The heat may damage the material.
That what happen when you try to close the top...the material get very hard or stiff when it cold...I brother work for Nissan dealer : he said " In the cold the top get very stiff and hard...the top motor work very hard to try to close the stiff top material...caution may damage the motor and top material..pro-long the top material life...Do not open the top when it cold...
Old Feb 1, 2009 | 03:25 PM
eddieboi28's Avatar
eddieboi28
just saw the post, all top down's are not suppose to be opened below 50* due to the fact that you are gonna damage the top cloth streching and lesser life on the fabric. even M3 owners dont open the tops below 50*.
