powerlab plenum spacer
Old Mar 4, 2009 | 06:19 PM
andychau's Avatar
andychau
Default powerlab plenum spacer
have anyone install powerlab plenum spacer? do u have problem after install?
Old Mar 4, 2009 | 06:36 PM
Mr. D's Avatar
Mr. D
Only problem I had post-install was the brace rubbing on the upper plenum, but that was easily fixed by adding a couple more spacers.
Old Mar 5, 2009 | 02:59 PM
andychau's Avatar
andychau
do u have problem with the gas pedal? Everytime i tried to accelerate, i feel the motor run hard and the gas pedal viberate. Wonder if u have the same problem?
Old Mar 5, 2009 | 06:18 PM
Mr. D's Avatar
Mr. D
I don't have that problem, but I think I read about that in another thread on here. Are you sure your brace isn't rubbing?
Old Mar 5, 2009 | 06:24 PM
Phreakdout's Avatar
Phreakdout
^^ For vibration, I agree ... add washers under the brackets for the strut bar to body connection.
For engine running hard, is it like it has no power or just noise? Sounds like an air leak. Maybe the gasket pushed out or in somewhere along the edge. Also check the three hoses around the throttle body and make sure they are all connected.
Old Mar 11, 2009 | 04:34 PM
andychau's Avatar
andychau
I found out the problem. It was the strut bar touch the upper plenum, that caught the engine run hard and it feel like it has no power. How many spacers did u guys put under the brackets?
Old Mar 11, 2009 | 09:53 PM
Mr. D's Avatar
Mr. D
I think I went with 4 spacers for each bolt.
Old Mar 11, 2009 | 10:02 PM
Ztouring04's Avatar
Ztouring04
i had the same problem felt like my whole car was shaking.......4 spacers is what i used also and never had a problem since......just my .02
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
