Rear Brake replacement
Old Mar 26, 2009 | 02:00 PM
ZULater05's Avatar
ZULater05
Smile Rear Brake replacement
Hi, I need some info. I want to changr my rear brakes and before I start I would like to know if there are any special tools that I need. I'm concerned about pushing in the pistons because of the emergency brake. Any help will be welcome. Thanks, Ed
Old Mar 27, 2009 | 09:55 AM
FishBrownie's Avatar
FishBrownie
I had mine replaced by a local member while I watched and learned. We didn't use any special tools, but if you can, keep your ebrake off for a while if you are changing the rotors too. My rotors were tough to get loose. If it is just a pad replacement, it should be easy and go fairly quickly. You can use your old pads and some clamps or large plier type of tool to push your piston back in. Be careful not to leave your calipers dangling while changing the pads. That's all I can think of at the moment.
Old Mar 27, 2009 | 12:51 PM
ZULater05's Avatar
ZULater05
Thank you for the info.
JjL
East Canada
Jun 12, 2019 03:04 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
