So who's NOT having problems with their convertible top?
Old Apr 24, 2009 | 06:02 PM
A3VT 74's Avatar
A3VT 74
na_350
the mechanism is not aligned properly causing it to slip... the top would have issues going up or down... i found the issue by just taking a look at all parts while the top was moving...
the teeth are not aligned, when u go up and down it gets aligned...
I aligned it and placed a washer and that was it...
Old Apr 24, 2009 | 06:28 PM
XV8Crisis's Avatar
XV8Crisis
Originally Posted by na_350z
Where do I begin...
I have two rips on the top... right by the rear window, and one right above that one. They get bigger and bigger so it blows. I can't leave the car out in the rain otherwise I wake up the next morning and my seat is wet. Good thing I made room in the garage and it sits in there now.
Next... The top gets stuck while the top is going down. It will get stuck right when it's 75% down then all of a sudden it feels like something jammed. I have to hit the close button and make it go back up a few inchs then hit the open button for it to go down completely down. I might be the only one with this specific problem but it's annoying having a convertible but you actually have to work at it to get it down or worst worry about it ripping some more.
So I'm looking into that idea of the removable hard top
i definitely have that same problem
Old Apr 25, 2009 | 10:13 PM
Lucsious350z's Avatar
Lucsious350z
when i bought my zr, it had a huge slash in it. so replaced it for a new black top. no problems yet and hope to keep it that way as to replace it , it cost me 2600. not cheap.
Old Apr 26, 2009 | 12:48 PM
na_350z's Avatar
na_350z
Originally Posted by A3VT 74
na_350
Thanks bro... I never thought about that. Good looking out... I'll look into that next weekend.
Old Apr 26, 2009 | 02:04 PM
johns350's Avatar
johns350
Default No problems here
Use it several times a day @9-10 months a year. When the temp is @55 degrees or lower, it does have an issue with going all the way down. No issues at all @>60.
Old Apr 27, 2009 | 06:10 AM
boardjnky4's Avatar
boardjnky4
mine works great!
Old Apr 27, 2009 | 06:30 AM
SirSpeedyZ's Avatar
SirSpeedyZ
Originally Posted by Chaser720
Interesting choice of wheels. I guess we all have to have our 15 seconds of fame...
FYI there is no need to post pictures if it doesnt pertain to the topic which as you stated yourself has already been discussed.
Sorry sir but you fail.
damn you are a douche
Old Apr 30, 2009 | 10:16 PM
SGS350Z's Avatar
SGS350Z
I got a '04 and the top has NEVER given me any problems. When I wash the car I just wipe the top down with the same soap. Like stated earlier, don't use pressure wash. You'll be fine.
Old May 10, 2009 | 06:43 AM
seducitvesounds's Avatar
seducitvesounds
na_350
Sorry to steal the post, but im having the same issues as na_350, would you mind elaborating on how you fixed it? and where i should be paying attention to? the closing of the lid is quite annoying.
Old May 12, 2009 | 09:09 AM
A3VT 74's Avatar
A3VT 74
you need to have someone else open and close the top.. then look at the moving parts inside the place holder of the top.. uncover it to see the moving parts on each side... sometimes the theet do not align properly causing it to slip...
Old May 12, 2009 | 03:41 PM
Delako's Avatar
Delako
Only problem ive ever had was once when the top closed it did not align properly to latch, but after opening it all the way then reclosing it was fine. No problems since.
Old May 12, 2009 | 04:20 PM
E.F. VaBeach's Avatar
E.F. VaBeach
I think I'm the one who originally identified the passenger side top seam separation problem on this forum years ago, and posted the pics that have been used by others since.
I had the top replaced under warranty, but was disappointed that it was the same factory fabric. Since then, there have been no problems, but my baby sits in a garage when not on the road. I have never had any problems with the open/close mechanisms, weather sealing, alignment, or electricals.
Old May 12, 2009 | 04:22 PM
E.F. VaBeach
Oh yeah - mine is one of the earliest roadsters made - produced in the initial production run in early summer 2003.
Old May 12, 2009 | 04:27 PM
taylorms's Avatar
taylorms
Thanks...I really appreciate everyone's input!
Old May 13, 2009 | 06:49 PM
shinobi89's Avatar
shinobi89
These cars have tops????
Old May 14, 2009 | 08:54 AM
Darkpath's Avatar
Darkpath
No problem with the top on my 06 - though it did seem temperamental one time at the end of winter - it was about 55 outside but probably only 45 in the garage - and it opened like an ol lady trying to get up off the couch... I stopped operations and pushed UP.. and after backing from the garage and letting it sit in the sun for 20 mins - it operated fine... So be aware that cold temps can adversely affect operation - not to mention the vinyl top is more brittle when cold - (and likely the cause of the above mentioned issue) causing it to fold and stow while cold may flex the vinyl too much and cause the material to crack vice fold... Let 60 degrees be the rule of thumb for operation.
Old May 15, 2009 | 06:52 PM
dkuvila's Avatar
dkuvila
ur dumb.... pics are always useful
Old May 15, 2009 | 07:31 PM
  #38
whittier's Avatar
whittier
I have an 07 roadster. So far no problems. Top opens/closes on an average of about 10 times per week, and car is garaged.
Old May 16, 2009 | 05:48 AM
  #39
johns350's Avatar
johns350
OP - where in TX are you located?
Old May 16, 2009 | 08:52 AM
  #40
taylorms's Avatar
taylorms
San Antonio
