2007 Roadster - Cannot add Key Fob
Old Jun 8, 2010 | 06:44 AM
mintlin's Avatar
mintlin
Question 2007 Roadster - Cannot add Key Fob
Hi,
I've got a 2007 350Z Roadster and I'm trying to add Key Fob remote that I've bought online.
I've followed the following instructions but my car's blinkers do not flash twice (at all) and I cannot register the new remote with the car.
1) Lock car using the power lock switch.
2) Insert Key 6 times in ignition within 10 seconds, removing the key completely from the ignition every time.
3) Blinks should flash twich -----> this is where I'm not getting...
I've followed the instructions from ********* wiki as well but same result; the blinkers do not flash and I cannot register the remote.
Please help!
Old Jun 8, 2010 | 07:29 AM
F34RL355's Avatar
F34RL355
just keep trying, use a steady constant pace keep inserting till it flashes i had the same prob eventually i go it after a 10 min of messing around
Old Jun 11, 2010 | 02:58 AM
mintlin's Avatar
mintlin
I've tried for 15 mins just now, with constant pace but still nothing..
Is there any other way around this?
Old Jun 11, 2010 | 05:33 AM
F34RL355's Avatar
F34RL355
just keep sticking it in and out untill the signals flash mioght take more then 6 times just keep doing it till it flashes then complete the steps
Old Jun 14, 2010 | 01:09 PM
dfresh713's Avatar
dfresh713
Master
I have done this before. If I remember correctly, there was some fault with these instructions, somebody posted slightly incorrect instructions. Look up for another.
Old Jun 14, 2010 | 07:40 PM
mintlin's Avatar
mintlin
I've looked up several other instructions and most of them say insert key 6 times / until the indicators flash.
The only difference is at the beginning of the instructions where some say lock the doors using the power lock button (which only locks passenger side) while others say use the driver's side lock toggle.
I've tried both but still cannot get the indicator lights to flash or be able to register the remote...
Still stuck..
Old Jun 16, 2010 | 10:58 AM
ncparamedic's Avatar
ncparamedic
Prodigal Son
Dealer..best option..if you are not getting the correct results.
Pleask
Dec 21, 2021 03:17 PM
Alexreyes
Sep 30, 2015 11:30 PM
