COBB ECU PROBlem
Old Mar 31, 2011 | 05:18 AM
Ramz1987's Avatar
Ramz1987
Default COBB ECU PROBlem
Hello, i have the map cobb on my 350z roadster 2004 automatic with manual differential installed, i chose stage 2+ option. (there is stage 1, 2 , and 2+)
my mods: upper plenum kintetix,lower manifiold motordyne, jwt intake with air filter, resonated test pipes, stillen light pulleys,ichiba headers, stillen engine damper.
all my friends told me that its very lean , beacuse the gas its not burning efficiently,and i can actually see the gas goin out of my exaust !!! what should i do ? should i go for stage 2 instead of stage 2+ so air and fuel will be equal? or do a custom map ? cobb team sent me once the software for custom map, but i dunno if i shld go for a lower map like stage 2 or a custom one. because i lost a race with same mods with my friend and he has stock ecu !
pls reply, thank u.
ramzi
Old Mar 31, 2011 | 06:23 AM
bmccann101's Avatar
bmccann101
"all my friends told me that its very lean , beacuse the gas its not burning efficiently,and i can actually see the gas goin out of my exaust !!! what should i do ? "
Dont listen to your freinds, listen to a wideband air fuel readout or a consult run..find out what youre really at for AF..... or bring it to a local shop that can tune it...not shore what Lebanon has for tunres tho.. cant help ya there...
Cobb doesnt support the 350z anymore.. but Id still give them a call if you have thier product.
Aside from frineds guessing its lean and seeing gas come out the back of your car (?) what are the actual symptoms..aside from losing a race w someone w the same mods.
Old Mar 31, 2011 | 06:28 AM
Ramz1987's Avatar
Ramz1987
2nd gear and on, the rpm moves not fast enough ! stock was better!, the only advantage is that the rpm is goin up to 7200. i guess im goin tomoro to custom tune it.
or again shld i drop one stage bmccann101 ?
Old Mar 31, 2011 | 06:54 AM
bmccann101's Avatar
bmccann101
custom tune is always what is necessary, rpm by rpm AFR and timing if posible.. im not sure whats avail on cobb... i run UTEC.
Old Mar 31, 2011 | 07:11 AM
Ramz1987's Avatar
Ramz1987
yes i got the custom software sent by their company, thx for ur help man
Old Mar 31, 2011 | 09:12 AM
terrasmak's Avatar
They support it, they just don't sell it anymore. I do believe the last update was the final update.
Old Mar 31, 2011 | 10:13 AM
tylerxfire's Avatar
tylerxfire
well this has fail right from the start..first of all get on a dyno or get a wideband that will tell u if u are lean or rich....second of all if u can see gas coming out of the tailpipe then that means you are extremely rich NOT LEAN..lean is when u are not getting enough fuel and rich is getting too much fuel..must be some pretty bright friends
Old Mar 31, 2011 | 10:14 AM
tylerxfire's Avatar
tylerxfire
u need to contact someone in your area familiar with the z and familiar with using the cobb software and have the car dyno tuned..if there is nobody in the area that tunes with cobb then u should change to what they do tune...
Old Mar 31, 2011 | 01:19 PM
silvertouringz's Avatar
silvertouringz
bro ur running RICH not LEAN! since ur saying gas is going out of ur exhaust...stage 2 is the way to go!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
