Fitting wheels inside roadster?
Old Jan 30, 2012 | 09:21 AM
nvrdun's Avatar
nvrdun
Default Fitting wheels inside roadster?
I will be picking up some 18" wheels and I need to know if I will be able to use the Z to pick them up? Can I stuff one in the cavity where the top goes? Will two fit in the trunk, two in passenger seat? These are wheels has anyone done this with a roadster?
Old Jan 30, 2012 | 10:05 AM
F34RL355's Avatar
F34RL355
ummm no its not gonna fit.... pull out ur spare, put one in there, throw another in the trunk on top of that one, then rinse and repeat, but then again i didnt want weels touching my seats so im sure u can fit them in the passenger if u want
Old Jan 30, 2012 | 10:25 AM
nvrdun's Avatar
nvrdun
Well I have to drive over 300 miles to pick them up, so that will not work. There are no tires mounted to the wheels, just the wheels. If I wrap them in blankets how many will I be able to fit them in the passenger seat?
Old Jan 30, 2012 | 10:46 AM
F34RL355's Avatar
F34RL355
oh didnt know it was just rims, u should be able to fit one in the roof hatch in that case 2 in the trunk and one on the seat to boot
JERZ350's Avatar
JERZ350
Without tires I'd imagine you might be able to fit 2 in the back next to each other? And the other 2 on top of each other on the passenger seat with string around the back of the seat.
Old Jan 30, 2012 | 11:38 AM
350ZZJoe's Avatar
350ZZJoe
I simply removed the spare tire + passenger seat to transport all 4 18inch wheels (with rubber).
This way you don't have wheels on your seat either. Seat comes out with 4 14mm bolts. Takes 5 minutes to do.
Old Jan 31, 2012 | 07:40 AM
nvrdun's Avatar
nvrdun
Well these are rims only no rubber, so will I still need to remove the seat?
Old Jan 31, 2012 | 06:11 PM
w210e55's Avatar
w210e55
Default 4 rims
I transported 4 inch rims from Houston to Dallas. I put 2 in the passenger's seat, one in the passenger floorboard and one in the trunk, it was fine. VERY TIGHT, but fine.
Old Feb 3, 2012 | 01:48 PM
nvrdun's Avatar
nvrdun
This is how I did it!!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Depravity
Oct 1, 2015 04:49 PM
