XM Antenna location on a Roadster
Old Mar 21, 2004 | 06:19 AM
Heather's Avatar
Heather
Default XM Antenna location on a Roadster
I performed a search on the exisiting posts for information on antenna mounting points on the Roadster, but didn't see anything.
Has anyone tried to mount an antenna? Being magnetic, we're running into problems finding a location that has a clean look, on metal, and will give us the best reception.
Any suggestions?
Old Mar 21, 2004 | 06:22 AM
Whataguy5431's Avatar
Whataguy5431
Default Re: XM Antenna location on a Roadster
I've been on this and a couple of other boards for about 5 months and haven't heard of anyone finding a suitable mounting point. Have heard that some put it up on the dash, behind the gauges, but still not sold on that place. I love XM but just can't commit to screwing up the looks of the roadster with an exterior mount.
Good luck in your search.
Any suggestions?
Old Mar 21, 2004 | 07:33 AM
adidaskobe's Avatar
adidaskobe
Default Re: Re: XM Antenna location on a Roadster
I had XM for about 2 weeks in my roadster right after i got it. I mounted the xm micro antenna on the center dash right near the edge of windshield. There is a small area there between the vents that fits the antenna perfectly. Reception was pretty good, did have usual dropouts under freeway over passes though.
Old Mar 21, 2004 | 08:52 AM
Pagan's Avatar
Pagan
I have a miata with XM, and I mounted the antenna on the forward leading edge of the trunk. It gets excellent reception there. I take my Z in on Tuesday for the stereo install, and I'll probably put the XM antenna in the same place. It's very subtle, certainly doesn't mess up the looks of the car.
Old Mar 21, 2004 | 09:53 AM
Heather's Avatar
Heather
Thanks - we planned to use the trunk as well, but unfortunately, that is fiberglass, so it won't work.
Old Mar 22, 2004 | 05:20 AM
westover's Avatar
westover
Any suggestions?
I also have the XM Radio antenna on the front edge of the dash between the vents. It has worked out great for me. A small piece of double sided sticky tape is all that is needed to hold it in place should you ever need to remove the XM unit, there would be no holes left behind to repair.
Old Mar 22, 2004 | 09:15 AM
Keo's Avatar
Keo
Did you guys buy the XM Roady?
Old Mar 22, 2004 | 12:43 PM
adidaskobe's Avatar
adidaskobe
For purposes of saving space, I went with the Alpine CDA 9820 XM. It's the worlds 1st headunit with integrated XM tuner inside headunit. I don't know what other people did but i didn't want to put the tuner under seats, trunk or any of the storage spaces.
If anyone interested in it, pm me. I switched to a different unit with DVD and MP3 capability.
Old Mar 29, 2004 | 09:14 PM
thisisbrent's Avatar
thisisbrent
Any suggestions?
Looking for the same answer with my Sirius antenna which I had on my previous convertable. Besides the antenna, how does the XM or Sirius integrate with the Bose on the Touring model?
Old Mar 29, 2004 | 10:52 PM
Rushguy's Avatar
Rushguy
Looks good on the dash.
Old Mar 29, 2004 | 10:56 PM
Rushguy's Avatar
Rushguy
Stupid thing won't let me edit pic or delete..heres what I meant hehe
Attached Thumbnails XM Antenna location on a Roadster-caraudiostuff2-025.jpg
Old Apr 14, 2004 | 10:46 AM
newhouse's Avatar
newhouse
I had the same issue with signal dropouts--just moved antena to outside windshield between the wiper blades--seems to work and does not screw up sheet metal and is hidden!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
