Blue Dots on Wheels
Old Aug 13, 2004 | 05:40 PM
Penderwheels's Avatar
Penderwheels
Default Blue Dots on Wheels
04 Roadster w/ stock 17" wheels. Build date 6/04. Each wheel has a blue dot on it. About 3/16 " diameter but not perfectly round. Random locations: Two wheels have dots on the spokes and two have them on the rim just outside of the spokes.
They almost look like they're under the clear coat. Scratching with thumbnail does not remove them but they feel slightly raised.
Sorry no pix.
Anybody got any ideas ???
Old Aug 13, 2004 | 06:15 PM
dkny_boi's Avatar
dkny_boi
I had some on my coupe 18" wheels upon pick up of my car. They rubbed off eventually when i washed them though.
Old Aug 13, 2004 | 07:05 PM
jakespeed's Avatar
jakespeed
The dots indicate the low spot (or maybe the high spot) on the wheel. There is a dot on the tire at the high spot as well. When the tires are mounted, these spots are lined up in order to try to get the most perfect round wheel/tire combination. If you scrape it off they can't line it up next time unless they use a road force balancer....or that is how it was explained to me.
Old Aug 14, 2004 | 08:43 AM
ezee's Avatar
ezee
The dots were applied by hand to hide imperfections in the paint. I carefully scrapped them off and found that each dot covered a tiny flaw, that is why they are in random locations.
Funny thing is the dots are much more noticable than the flaws they attempt to hide.
Old Aug 20, 2004 | 11:45 AM
jsheldon's Avatar
jsheldon
This is close. Actually: " Original Equipment (OE) tire suppliers are required to mark the tire's “high point” while OE wheel manufacturers mark the wheel's “low point.” This helps the vehicle manufacturer match mount combinations that maximize new car ride quality while reducing the amount of balancing weight."
Old Aug 22, 2004 | 09:37 AM
rjaustin's Avatar
rjaustin
Mine are grey -- I almost didn't notice them
Obadabot
Jun 18, 2023 11:31 PM
