how much up and down can the top handle?
Every time I park in a public place, I put the top up. I put it up in the parking lot at work. When I'm driving, it always goes down. If I'm running errands on a Saturday, the top may go up and down 5-6 times in a day. How much do you all think is too much. Will I wear out the motor or have top fitment problems in a year?
I am constantly putting it up and down as well due to flash rain storms and the fear of having anyone lift anything from inside the cab. As long as it is under warranty I recommend using it frequently to uncover any problems you might have. I have already had my top and frame replaced under the “pinhole” problem. As you continue to use it keep an eye on the top of the window frame where is latches in the center and on the sides for wear and every now and then check the latches inside the cover for chipping or wear.
My guess is that Nissan designed the motor to work under normal use for as long as the warranty covers it (and not one day more). If you use it a lot and it goes out before then, you will get it replaced for free… If you use it much less and it goes out a day after the warranty expires then you gotta pay for it all.
Just do it when the car is running. That top mechanism is a huge strain on that battery.
Actually, I think that "excercising" the top is good for it. It keeps the material flexible, and doesn't allow for the bushings etc in the frame to dry out.
I have 7200 miles on my 11 Month old baby.
The top motor is aleardy failing on me. After the top goes up and it is finishing up the motor still runs for like 3 seconds, so you hear a grinding noise. The parts are on order for them to replace it now.
350Z_Al
Oct 29, 2020 07:44 PM
