370Z Engine & Drivetrain VQ37 Power and Delivery
oil consumption... again
Old Aug 15, 2010 | 07:54 PM
johnwigs's Avatar
johnwigs
Default oil consumption... again
in an attempt to meet NHTSA 30MPG standards, nissan chose an inferior ring pack set... again... engines consuming oil at an alarming rate... $12k for short block when all said and done with actuators and sensors added to short block and labor... get your oil consumption tests done!!!
Old Aug 15, 2010 | 08:11 PM
dmroberson's Avatar
dmroberson
define alarming rate... and my long-block replacement cost over $17K when it was all said and done. $12K sounds do-able, but a little low.
Old Aug 15, 2010 | 08:13 PM
johnwigs's Avatar
johnwigs
no oil on dip stick after 1000 miles... thats alarming to me...
Old Aug 15, 2010 | 08:19 PM
POWUH's Avatar
POWUH
my long block replacement was 9.5k , no oil consumption yet. are you still under warranty?
Old Aug 15, 2010 | 08:31 PM
dmroberson's Avatar
dmroberson
I agree. Was just curious. Sorry about the post. Didn't realize it sounded as blunt as it did. lol. Been a long day.
The worst for me was my 2nd engine... was losing about ~2 qts every 1000 miles.
Old Aug 15, 2010 | 08:55 PM
Do you have statistics to back this up or is this just anecdotal?
Old Aug 15, 2010 | 08:58 PM
johnwigs's Avatar
johnwigs
not to say "every" engine needs replacment but Ive done a nismo short block replaced @2nd oil change (7k)... its nissans 3rd set of ring packs to try to get it right
Old Aug 15, 2010 | 09:02 PM
johnwigs's Avatar
johnwigs
not anecdotal... I (up until 2 days ago) worked for nissan... there is a bulletin... I don't have it in front of me... nor do I feel the need to look it up... im only informing the masses of a problem... feel free to take it or not
Old Aug 15, 2010 | 09:14 PM
surfcity40's Avatar
surfcity40
Are you having a consumption issue and what is your source on the "inferior ring" allegation.
Old Aug 15, 2010 | 09:18 PM
johnwigs's Avatar
johnwigs
refer to post #8
Old Aug 15, 2010 | 09:41 PM
johnwigs's Avatar
johnwigs
***EPA standards... not NHTSA standards... those blokes deal with crash standards and stuffs
Old Aug 15, 2010 | 09:57 PM
surfcity40's Avatar
surfcity40
refer to post #8
dood, I referred to post 8 and you didn't tell me from where the "inferior ring" allegation came.
If there is a consumption issue that is one thing. I'm merely asking you where you obtained the information about Nissan buying inferior rings.
That isn't a rocket science question. That is a "What is your source?" question.
I'm not calling you out but right before me David asked if this was "anecdotal". That means are you perpetuating an intarweb story as opposed to offering something we can hang our hat upon.
no disrespect.
Old Aug 16, 2010 | 05:23 AM
F34RL355's Avatar
F34RL355
does this affect the 35HR?
Old Aug 16, 2010 | 06:33 AM
Zazz93's Avatar
Zazz93
no disrespect.
He is or was a Nissan Tech and the bulletins from Nissan is where he getting his info from.
Old Aug 21, 2010 | 09:20 PM
johnwigs's Avatar
johnwigs
there has not been any reports of oil consumption issues with the HR... the ring pack and piston are different in the HR... the change for the VHR was for fuel mileage (less tension)... the updated short blocks have higher tension springs (supposedly chromoly coated... I havent confermed it... no need to take apart a good new motor)
Old Aug 22, 2010 | 05:39 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
if it doesn't affect an HR then why the short block replacement on the NISMO (post 7)? other reasons?
HR's have their own set of issues to them, most notably, the crappy bearings and resultant oil temps. Though overall, the remaining internals are superior to the DE's
HR springs are much stronger than DE springs, and yes. They will easily take 11mm of lift, where a DE spring can't even think of that. We just did a set of heads for a VHR build, will have to check if there was anything else notable about the springs
Old Aug 24, 2010 | 08:01 AM
johnwigs's Avatar
johnwigs
Z34 nismo with 7400 miles... ran oil consumption test... dip stick dry after 1000 miles!!!!... ya the aluminum bearings are crap... swap them out for trimetal and they will last... aluminum bearings crap out around 300 degrees of oil temp... sucks since normal driving (VHR) is about 250-275 (without oil cooler) dosent give much space for error... VHR springs are tricky... the exhaust springs are the same as HR... but the unobtanium intake springs are 187-211 open pressure... even the GTR springs arent that stiff (92-102int and 109-123exh)... just a side note the VHR can open past 12mm (adjustment of the nuts on the fulcrum arm all the way... adjusts the lash to zero)... verified on a junk head... not really sure about adjusting nuts on a good engine... damn the silicone on the VHR is alot to handle!!!!
Old Aug 24, 2010 | 10:22 AM
johnwigs's Avatar
johnwigs
no disrespect.
NTB10-090
so every one can sleep well knowing its not anecdotal... or to know "my source"
Old Aug 24, 2010 | 05:20 PM
bacalhau16's Avatar
bacalhau16
I'm about to hit 1000 miles on my 370. If the dipstick is dry, I'm leaving it there at the dealership and not picking it back up.
Old Aug 25, 2010 | 07:27 PM
johnwigs's Avatar
johnwigs
thats not how it works... 1000 miles???? you haven't even "broke in" the engine yet... and Im sure you have WOT and reved over 4k... sales doesn't tell people how to care for their new car
oil consumption can start @ 2nd oil change... its alot easier to get nissan to approve work then... then customer drives for 500-1000 miles and then the dipstick reading is measured... oil level excessively low then you get whats behind door #1... a new short block... no oil consumption then you are good to go... this bulletin applies to vehicles built before april '10...
now I must go Fast and the Furious is on!!!!
"granny shiftin not double clutchin like ya should"
