370Z Engine & Drivetrain VQ37 Power and Delivery
Custom intake manifold and cold air intake
Old Mar 16, 2020 | 06:46 AM
Kimch1Pwr83's Avatar
Kimch1Pwr83
Default Custom intake manifold and cold air intake
Hi,everyone. Couple months ago I got into an accident and the 370z was written off. I am working on getting another Z.
In the mean time, I will be making custom intake manifold and cold air intake. Can anyone tell me the measurements for the following:
Upper intake manifold height
upper intake manifold width(not where throttle body is)
lower intake manifold(from cylinder head to where upper intake manifold attaches)
Cold air intake( from throttle body to maf)
(From throttle body to where pipe bends at bumper)
Appreciate your help guys. Thanks
Old Mar 16, 2020 | 08:30 AM
bealljk's Avatar
bealljk
please post your progress and results … I would like to see what you come up with.
with that being said -
just buy a replacement from the Z1 or ebay or wherever. To think you can improve on Nissan's and/or Z1s design is a fools-errand. Learn from the zillion attempts (both professionally and amateurly) on the DE engine. A million different intakes are available for the DE and none (with the exception of the Cosworth) are better than OEM.
But I commend you for trying!
Old Mar 16, 2020 | 08:38 AM
Kimch1Pwr83
Its going to be a 3 inch cold air intake. Its worth a try. Not going to start until I get the numbers. Its for a VQ35HR , not a DE
Old Mar 16, 2020 | 08:41 AM
Kimch1Pwr83
Admintuning made a 3 inch cold air intake.
These intakes have been proven to be the most powerful intakes available for the 350Z VQ35HR platform. In our testing, these intakes have added 35whp and 24wtq over the stock airboxes (with a tune), adding significant amounts of power everywhere on the powerband.
Not sure if its dyno proven.But I am not spending $600 USD since I am from Canada.
Old Mar 16, 2020 | 09:11 AM
rustyschopshop's Avatar
rustyschopshop
Honestly measurement won't help you much if you don't have a car to work fitment on. Once you have your car you can do your own mock up to make sure it can fit. Also larger tubes require tuning, this is not an option. Must be done
Old Mar 16, 2020 | 09:27 AM
jhc's Avatar
jhc
General & Tech Moderator
I measured before installing my DE CAI. The diff was literally -6F than stock location w a laser thermometer. Stock is poly-composite, aftermarket is usually metal, so heat-soak. Knock yourself out.
Old Mar 16, 2020 | 10:22 AM
bealljk's Avatar
bealljk
I'm all about helping and don't take my posts as 'hate'
I understand it's an HR. The HR has 2.5" throttle bodies? and you're going to put a 3" intake up to that point? Do you plan to re-tune?
Post up your progress, your thoughts, sketches, etc -
I actually did my own intake on my DE and I picked up 328hp after I tuned … albeit, two turbos were on the ***-end of my custom intake.
Old Mar 16, 2020 | 11:18 AM
Kimch1Pwr83
jhc its just to give me an idea, I cal always add more or take less off. But then, I do understand your point.
Old Mar 16, 2020 | 11:21 AM
Kimch1Pwr83
Sorry,meant rustychopshop.
jhc- there are somethings you can do to minimize heat soak, thermal wrap is a idea.
as for the other poster. Will try to do a sketch soon and post
Old Mar 18, 2020 | 09:42 PM
DarkZ03's Avatar
DarkZ03
Cosworth is better than OEM for boosted applications not NA, it will lose power like anything else out there.
Old Mar 19, 2020 | 06:57 AM
Kimch1Pwr83
Incase anyone needs the measurements
Got the measurements.
Width: from TB to TB 18 inch
Height: 6 inch
Nick_MF_350z
Aug 5, 2016 04:30 AM
goose691
Apr 28, 2014 01:20 PM
vfr350
May 7, 2003 04:25 PM
