370Z Maintenance & Repair 370Z upkeep and diagnosing/fixing problems
Check engine light popped up
Old Jan 1, 2018 | 02:21 AM
Xhino's Avatar
Xhino
Default Check engine light popped up
Hey guys recently bought my 2007 350z I love it but yesterday my check engine light turned on. I had to go put some gas cause I was low and as I was putting gas the pump stopped at like 5 gallons withought being full. I tried to put more gas again but the pump would stop again with my gas tank being at almost halfway. I am not sure why it was doing it will the check engine light have something to do with it? What could it be? Need to mention that The temperatures right now in my area are way below freezing (5 degrees Farenheit) so I don't know if that has anything to do with it. Need help to turn that engine light off!! Thank you
Old Jan 1, 2018 | 05:12 AM
karlt's Avatar
karlt
Nissan published a Service Bulletin, NTB17-030, describing slow of difficult to fill fuel tanks on virtually all Nissan vehicles, including 350Zs. The problem seems to be the vent line from the fuel tank to the charcoal canister. The Service Bulletin describes the diagnostic procedure and requires a piece of factory test equipment. However, this procedure is covered by an extended evaporative emission system warranty of 15 years or 150,000 miles, whichever comes first.
You can find the Service Bulletin at https://x.nissanhelp.com/forums/Know...ase/links/256/.
You will need to register to view or download bulletins.
You can also see the extended warranty letter that was sent out at http://www.nissanassist.com/web/EVAP...ls.php?menu=81.
Old Jan 1, 2018 | 05:52 AM
travlee's Avatar
travlee
Master
try turning the pump handle some, and also learn to post in correct section
eliopulos_2jz
Jul 25, 2014 05:05 AM
Copperz33
North East
Jul 27, 2009 06:31 AM
inczero
Oct 16, 2008 11:53 PM
BamBam
Mid-Atlantic
43
Aug 9, 2006 04:54 PM
BamBam
Aug 9, 2006 04:10 PM
