Remote window Up/Down with aftermarket alarm
Old Dec 21, 2004 | 07:30 PM
KPierson's Avatar
KPierson
Default Remote window Up/Down with aftermarket alarm
I was asked to repost this information as the site that previously hosted it no longer has the picture.
This application can be used if you have an aftermarket alarm with only one AUX channel availible. It uses a relay to allow you to either raise or lower the windows by pushing the AUX button. If the alarm is armed the windows will go up when the button is pushed, if the alarm is disarmed the windows will go down.
A validity channel is any channel that outputs a signal for as long as you hold the button down.
This information is being provided with no warranty. It may or may not work in your particular application. Check with a professional installer if you have any questions.
For OEM Window Up integration check out www.KPtechnologies.net
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
