Need some advise on choosing an amp
I have a 12" phoenix gold TITANIUM ELITE dual 4 ohm subwoofer, 1200/2000W (RMS/PEAK). Any suggestion on a decent amp that can push this sub?
Phoenix GoldOCTANE-R 15.0:1 1500w MONO CAR AMP AMPLIFIER - ebay price $290
• High efficiency Class "D" monoblock amplifier
• 18dB variable LP crossover
• 18dB variable subsonic filter
• Low Pass Level port (LPL)
• Dimensions: 14.5L x 10.875W x 2.25H
1500W x 1 (2 ohm mono)
max power
Phoenix Gold XENON 1200.1 X1200.1 CLASS D Amp - ebay price $435
• High efficiency (greater than 80%) Class D Operation
• Buffered RCA full range thru output
• Remote Monitoring Display (RMD) port
• Low Pass Level control ready (LPL-44)
1200W x 1 (4-1 ohm)
JBL GTO1201.1 1200 WATT MONOBLOCK AMPLIFIER - ebay price $289
~ Efficient High-frequency switching Class D power supply
~ 12dB per octave electronic crossover
~ RCA low-level inputs
~ Full-range preamp outputs
~ Variable bass boost circuit for optimized system response
~ 787 watts RMS x 1 @ 4 ohms
~ 1114 watts RMS x 1 @ 2 ohms 14.4V supply
~ Dynamic Power 1339 watts at 2 ohms
~ Damping Factor: 6.348 at 4 ohms
~ Frequency Response: 10Hz - 302Hz
~ Maximum Input Signal: 6.1V
~ Variable electronic crossover and bass-boost
all of them are all less than 450. And i am actually looking to pay less than 400. So which one do you guys thing would be suit the sub? Or any other suggestion?
max power
1200W x 1 (4-1 ohm)
JBL BP1200.1 was reviewed/benched to make about $1280w @ 2ohms. I've owned it 3x
I personally hate having a final load of 2ohms; it's such a pain to get max power from amps. Prefer D2's for either the 1ohm class D load, or 4ohm for bridged AB operation.
I don't know anything about the sub or the GTO amp you pasted, but going off the RMS of the sub .. the BP1200.1 makes the power it wants.
I don't think the Xenon 600.1 (600w?) would be enough .. but can't be sure b/c like I said, I dunno anything about your sub.
I personally hate having a final load of 2ohms; it's such a pain to get max power from amps. Prefer D2's for either the 1ohm class D load, or 4ohm for bridged AB operation.I don't know anything about the sub or the GTO amp you pasted, but going off the RMS of the sub .. the BP1200.1 makes the power it wants.
m_0g
Jun 3, 2021 10:05 AM
Tochigi_236
Sep 27, 2015 03:40 PM
