Help:: Amp Over heating?!?!?! in our glove box.
Old Feb 17, 2005 | 07:46 AM
YBLegal's Avatar
YBLegal
Default Help:: Amp Over heating?!?!?! in our glove box.
hey guys.. i just installed an amp on our glove box.. behind the passanger seat
if i drive my car for about an hour i could smell my amp burning up...
i saw lots of people that put their amp on their glove box.
any problem heating up or any kinda solution to resolve this..
i was may be thinking cutting out an hole on the bottom of the plastic piece.. to let it ventilate..
any help would do~
Old Feb 17, 2005 | 08:23 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
does it cut out or just smell?
and what amp is it?
Old Feb 17, 2005 | 08:36 AM
YBLegal's Avatar
YBLegal
just smell.. and to the touch. it was VERY hot..so i had to let it cool down for about 10 min while i was driving..
ABS9030 2 CHANNEL 600W AMP Maximum Power Output 300W x 2CH (600W) @ 20HM Power Output: 130W X 2CH @ 20HM 80W X 2CH @ 40HM MONO: 260W @ 40HM THD less than 0.05% LPF (Low Pass Filter) Variable 30Hz - 250Hz HPF (High Pass Filter) Variable 50Hz - 1KHZ Bass Boost (+5dB @ 100Hz) 2 OHM Stable Stereo Low/High Level Input Frequency Response: 20Hz - 20KHz Gain Control, Power Indicator Gold Plated RCA Jacks
running new Punch 10"
Old Feb 17, 2005 | 08:43 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Is the sub 4 or 2 ohm?
Im going to guess that amp uses far too few mosfetts or the power supply really sucks.
Your best bet is to buy a 12v DC computer fan and cut a hole in the side of the glove box and hook the positive lead on the fan up to the remote turn on the amp.
This may not help, or It may help. Its what I can come up with short of investing in an amp that measures up to the quality the car said amp is going in.
Old Feb 17, 2005 | 08:54 AM
YBLegal's Avatar
YBLegal
wow.. if the power supply sucks the amp over heats?? cause it used to have slow burn fues. but during the install i burned it so in replacement. i got fast burn fues in there.. that might be it?
Old Feb 17, 2005 | 08:59 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
where is this fuse? Inside the amp?
Old Feb 17, 2005 | 09:08 AM
YBLegal's Avatar
YBLegal
the fues that i am talking about is from the Battery. on the 10gage wire that i ran. its an 30amp round with gold plate.
Old Feb 17, 2005 | 09:20 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
oh, no that wont matter a bit
Old Feb 17, 2005 | 09:42 AM
zand02max's Avatar
zand02max
When you are driving just take the panel off, that helps with cooling, or buy a fan,
Old Feb 17, 2005 | 09:52 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
...or buy an amp that doesnt suck at life
Old Feb 17, 2005 | 10:00 AM
zand02max's Avatar
zand02max
I had a Rockford Fosgate Power 1000 and Power 800 and a 3 Farad Cap in there and never had one problem.
I would get a different amp.
Old Feb 17, 2005 | 10:14 AM
YBLegal's Avatar
YBLegal
hmmm i really dont want to get a new one either.. any other suggestions?
Old Feb 17, 2005 | 10:31 AM
zand02max's Avatar
zand02max
(2) alternatives:
(1) Buy an amp fan.
(2) Mount the amp elsewhere.
Old Feb 17, 2005 | 02:05 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
My PC is in my glovebox and in the summer it can get pretty hot back there. The PC itself has a fan but I cut a few holes in the very back of the box to ventillate a bit. Someone suggested mounting a small fan back there. It could easily be wired to the rear Cig. lighter. I didn't ever need to do it but its not a bad idea.
Finally, someone tried to run a tube from his AC vent under the dash under the center console and into the box to keep it cool. I don't know how that worked but I saw pics of it.
Let me see if I can find them.
Old Feb 17, 2005 | 02:14 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
His name was Zakira over at Frenzy. Here was his post:
To provide cooling to the glove box, I ran a black 1/2" plastic tubing (like a conduit) from the front HVAC duct through the center tunnel to the glove box (all stealth). But since I didn't want to cut into the stock HVAC duct, and since I didn't want it to be a permanent install (since in the winter you would have heater on and you don't want that sent to the back), I simply stuck the tubing into the HVAC outlet at the bottom of the driver foot well and tucked under the dash plastic (there is room if you feel for it). You can't even notice the install if you didn't know it was there. I still have to test and tweak to get this perfect, though, but it's an idea.
Here was the pic he posted:
Attached Thumbnails Help:: Amp Over heating?!?!?! in our glove box.-2.jpg
Old Feb 17, 2005 | 03:04 PM
Th3Cleaner's Avatar
Th3Cleaner
I use a F450 Alpine (glovebox) and after an houre of Pure bass rolling it does shut down for a few seconds, I assume it is the heat..my ohms are correct.
dual 10" Diamond Audio
I am also going to install a PC in the area where the original 10" would go behind the Driver seat
Old Feb 17, 2005 | 03:21 PM
YBLegal's Avatar
YBLegal
hmmm... with all these trouble.. mines well mount it under the passanger seat.. LOL but will try the PC fans out. .dont sound bad at all
Old Feb 17, 2005 | 04:29 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
absolute quality, finally figuered it out!!
Old Feb 17, 2005 | 07:28 PM
YBLegal's Avatar
YBLegal
??? huh???
m_0g
Jun 3, 2021 10:05 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
