Is This possible? Daisy chain amps
Old Apr 21, 2005 | 03:37 PM
thezman79's Avatar
thezman79
Default Is This possible? Daisy chain amps
Evenig all,
Got the bose system and would like to keep the stock deck for now. I have the following amps
PG XS4300
RF 1000bd
Here is what I am thinking. Since the PG XS 4300 has high signal inputs, could I tap into the rear speaker wire to get the source signal and then feed this signal to the 1000bd? I do not want to change my components for the moment but would like to have the amp ready to go when I do.
I this even possible or will I have to go with a LOC?
Thanks for your help
Old Apr 21, 2005 | 03:55 PM
DmanG281's Avatar
DmanG281
They make wire to RCA adapters so you can tap the rear speakers for an input and use that instead. Do this twice and your golden. I know JL Audio makes them, Phoenix Gold I believe also makes them. You can get cheapy ones also. Its not really daisy chaining the amps either. I thought you had meant running your amps parallel to each other to boost power but anyhow. I hope that helps.
Ahsmo's Avatar
Ahsmo
Imakecopies
you can do that
Old Apr 21, 2005 | 03:57 PM
DmanG281's Avatar
DmanG281
Just reread and am changing my statement. Do this once and use the output from the amp with the higher voltage if it has signal outs.
Old Apr 21, 2005 | 04:02 PM
thezman79's Avatar
thezman79
but since my 4 channel amp has high signal inputs, cant I just tap in the rear speaker wires using that?
Also, would the sound quality be better with a Line out converter or the high imput signal from the amp?
thanks for any help,
Audio newb here
Old Apr 21, 2005 | 04:04 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Audio newb here
They both sound like ****, so just use the high level inputs on the PG amp and jump a RCA line off the aux outputs to the RF amp.
lapham3
Oct 7, 2022 03:15 PM
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
Shane86
Sep 17, 2015 05:33 PM
