Sub In Factory Location
I have a base model Z with no sub woofer insert behind the driver seat, I know I cant buy a panel with a speaker grill to fit a 10" speaker, but should I? Is that enclouser to weak to put a JL audio? I am not looking to rock any windows, but just have thump when hearing my Linkin Park/Korn!
do a search my friend before flame war 05 starts. We have beat this horse to death.
Yes: you can put a sub in the stock location.
No: you cant do it without any work, unless you have someone do it for you.
Yes: Linkin park and Korn both blow hard. :P just kiddin.
seriously though, not trying to be an ***. Do a search before you type, people will be more apt to answer your questions.
l8er
l8er
l8er
l8er
l8er
l8er
i've used the stock location with dynamat and it sounded ok, then i bought a box of ebay for $100 that fits under the rear strut tower bar and it sounds ridiculous. no comparison. sue the space behind the seat for ur amps and satellite tuner.
I agree that there is not a lot out there for the stock space.
I put an amp that I already had in the glove box, used an Navone line out converter from the head unit, about $120 worth of Dynamat in the stock sub location, and put a $55 Pioneer 254f 10'' sub in the stock location.
The sub doesnt hit quite as hard as it would if it were in a box, and certainly doesnt hit as hard or as low as a 12'' or 15'', but I think it is still a great improvement. Definitely sounds A LOT better than the Bose system, and at a fraction of the price.
I also have a Roadster and the sub shakes the rearview mirror with the top down going 70 mph.
Do what I did. Get a place to do a fiberglass enclosure for you in stock location. Sounds GREAT. Saves space, especailly if you have a roadster. 10" JL Audio.
Edit: PM me if you are in SOCAL.. I can hook you up with a good price and great people.
if you take off the plastic covering on that spot you should see a peice of metal with a 9.5" hole cut out already. find a sub that is recommended for infinite baffle, screw it in hook it up and enjoy. It won't sound as good as a sealed or ported sub in a better location but it'll give you that little extra bump your looking for.
When looking at the specs of a sub for IB application a QTS of .7 or above means it's well suited for IB setups, though there are a few exceptions.
www.edesignaudio.com all of their subs are IB capable, even with low Qts, just don't give them as much power as they would normally get in a box. call them up and they can help you figure out what will sound best.
Tochigi_236
Sep 27, 2015 03:40 PM
