HELP! i put a hole in my speaker, just a little bit.
Old Apr 28, 2005 | 04:01 PM
zmespeed's Avatar
zmespeed
Unhappy HELP! i put a hole in my speaker, just a little bit.
ok i had to remove this one screw because the others didnt line up. so i was pushing because other wise the power drill would not grip. then the screw started twisting in the poly fil and foam liner and it whent crooked throwing the drill off and it hit the speaker i have sealed off the incloser that it is in so i think that when it moves air must be forced threw there.
how could i fix this. a little silicone or somthing?
btw its the back speaker
Attached Thumbnails HELP! i put a hole in my speaker, just a little bit.-speaker.jpg
Old Apr 28, 2005 | 06:16 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Not the end of the world.
The hole is small and doesn't "short" the speaker's sound waves. A bit of leakage like this is anyoying more than audible. If there's enough gasket left on either side of the hole you might try a bit of "super glue" with a toothpick. If the hole runs from the edge to the cone the super glue is going to rip apart so try the same toothpick treatment with Silcone II kitchen glue.
If you bought them from Circuit City and bought the extended warranty ... it's suppose to cover such damage - at least that's what they told me.
Old Apr 28, 2005 | 06:20 PM
zmespeed's Avatar
zmespeed
nope, ebay. i its not from edge to edge but i still dont like how hard super glue dries. so i think ill try some of that sillicone II. thanks i feel much better now.
edit: would liquid nails be ok? iv got some of that just siting around.
Old Apr 30, 2005 | 07:54 PM
JimRHIT's Avatar
JimRHIT
you want something to put on there with equally as much compliance as the surround itself ... I would suggest an inner-tube patch
In a sealed box, this hole is pretty bad .. as you box is no longer technically sealed .. so I would fix it.
Of all things to do, please dont use Liquid Nails
Old Apr 30, 2005 | 10:56 PM
zmespeed's Avatar
zmespeed
i used some silicone II it matched color wise (it comes in like all the colors of the rainbow) and seamed that it was kinda squishy so thats good. ill check tomorrow when its supose to be 100% cured. and see how its going..
Old May 1, 2005 | 07:37 AM
Santacruzslick's Avatar
Santacruzslick
Veteran
Ka-BOOM!!!
kyin
Oct 15, 2015 05:54 AM
