Xbox in my Z!! parts needed??
ALright i finially decided just to put my Xbox in my car...So i was wondering what parts would i need to be able to play on my factory bose system?? I know i would need a power converter right?? were could i get these parts from?? Any info would help...or what would you do??
Well fisrt of all you need a tv and depending if your tv has rca inputs or not , if it does then good you can connect the xbox rca's into your tv AUX channel if not then you will need to buy a AV SWITCHER so you will be able to switch from video modes , and yes you will need to buy a power converter. and thats about it anything else you need you can PM me. hope that helps
i was getting the xenarc 7" 700V w/ 2 AV Inputs i was going to get the Xenarc tvs with touchscreen but whats the use if i wouldnt be able to use it...Cause what i was told with the xbox you wont be able to use the touchscreen... But how would i be able to play the xbox with my factory bose system.. I can i configure it so i can use the volume on my bose?? What would i need??
Cool so i know a little bit about installing stereo's...I know i can install the screen and mount the xbox...But would it be easier to just take it to a shop and have them do it?? Cause i dont know where to get the things i need to complete it..
you can possibly just buy the things you need which should come with instructions , or if you just want to save the hassle take it to the shop , just make sure the shop has worked on a Z before .
alright cool...So what would be the best screen to get... I heard the "Xenarc 7" is a good one...but i dont need touchscreen or do I?? Which screen do u recommend that will fit flush?
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
