Pioneer Avic N2 - QUESTIONS
Old Jun 6, 2005 | 01:40 PM
mlam002's Avatar
mlam002
Default Pioneer Avic N2 - QUESTIONS
I located a brand new Pioneer Avic N2 for a little under $1500.. I actually found 2 places in Los Angeles that carry this particular model for this particular price. Brand new not refurbished. How much was your N2 unit?
Also.. I've been calling around to see if anyone has bypassed the security interface for the unit that allows you to drive and watch DVD's at the same time.
I have found 3 places in the Los Angeles area that have bypassed the DVD security.. the guy told me they hooked up the wire to the rear view camera or something tricking the gyro something something.. I dunno wasn't really listening but they said they could do it. Can anyone vouch for these guys? because the research that I've done so far was the nobody could bypasss the security interface on the N2 model.
thanks!
Old Jun 6, 2005 | 02:57 PM
THEDUKE's Avatar
THEDUKE
You can do that, but you get a message at the bottom of the screen, letting you know that objects might be reversed or they are larger than they appear. I dont remember which one it is.
Old Jun 6, 2005 | 07:47 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Connecting the rear screen monitor output to the rear camera input is just going to put the DVD output onto a portion of the screen - along with the warning. The other portion of the screen says navigation. This is all based on my reading of the owner's manual.
I don't think anyone's beaten the software yet. There are plenty of people claiming that they know how to do it but refusing to state the procedure for fear of causing global nuclear war or something. Personally I think that they're spouting bs and the system hasn't been beaten.
Driving with a DVD movie playing is a bad thing but I would like the ability for my navigator (wife) to be able to change the navigation destination while moving.
Old Jun 6, 2005 | 11:56 PM
mlam002's Avatar
mlam002
bump thanks.can anyone else chime in?
Old Jun 19, 2005 | 07:06 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Yes, the N2 is compatable with the Z's DIN mounting.
Old Jun 20, 2005 | 06:42 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Originally Posted by rich150001
What's DIN mounting?
I guess all I'll need to install extra is just the wiring harness and mounting kit(i'm guessing this is the DIN kit). Thanks for the help.
I believe:
single DIN = 7in x 2in
double DIN = 7in x 4in
Old Jun 20, 2005 | 05:36 PM
Dream's Avatar
Dream
My friend said to put any 12 volt signal to the parking brake wire to allow you to drive and play dvds.
I think that advice was for the N1, not the N2. I believe the N2 has a different means of detecting whether the car isn't parked.
Old Jun 20, 2005 | 09:26 PM
Boosted521's Avatar
Boosted521
the only way to bypass it is to find out how it detects movement. all older models that connect to the parking brake can easily be bypassed... you just ground the parking brake wire. i'd like to know how the n2 detects movement.
Old Jun 21, 2005 | 08:21 AM
THEDUKE's Avatar
THEDUKE
It uses the internal gyroscope of the Navigation system. If you disable that, then your Navigation portion of the unit will not operate properly. Plus it takes quite a bit of knowledge to actually open the unit up and disable the gyroscope.
Old Jun 23, 2005 | 08:25 AM
s3fddiZ's Avatar
s3fddiZ
Warning, if you tamper with the gyro your navi will be off and you will lose the vehicle dynamics function of the navi (the whole reason i bought mine.) I'm in the process of finding the code on the install disc that came with it to bypass the gyro and detect the parking brake. I will keep you posted with what i find.
Old Jun 25, 2005 | 01:01 PM
zonester's Avatar
zonester
You can by pass this by not wiring the VSC (Speed sensor). You will be off by approx 15 to 25 ft when dealing with NAV though. But i think that's not too bad..
Reason - that's how the Gyro sensor knows if the vehicle is trely moving or not.
I can't tell you where I got this info but trust me. it works. good luck!
Old Jun 28, 2005 | 03:20 PM
zrdude's Avatar
zrdude
Old Jun 30, 2005 | 06:59 AM
zonester's Avatar
zonester
Good luck Rich!
If you have any questions, let me know. I've installed it 3 times already and took my car apart in and out 4times... Pretty familiar with 350z.
Old Jul 1, 2005 | 06:36 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
So far though, we were unable to bypass the dvd. We will try one more thing. Does anyone know if you put the ebrake up 1 mm and will that allow it to work?
Nope - you could simply wire a switch in paralell with the emergency brake if that was the issue. The N2 uses the gyro sensors inside to feel the car moving - they detect the changes in inertial the same way your "butt dyno" does just at a level that your "butt dyno" can't measure.
I just installed a second video screen.
Old Jul 1, 2005 | 06:51 AM
s3fddiZ's Avatar
s3fddiZ
Where did you guys with the N2 place your brain unit. The logical place is under the seat but its not a flat surface. If you placed it there what did you to to make it lay evenly flat?
Old Jul 1, 2005 | 09:00 AM
zonester's Avatar
zonester
Guys, I had it under the pass seat for now almost a year. Its perfect. your gyro sensor will calibrate everytme you turn it on. as long as you place it front position (marked by an arrow i beleive), you will have no problem. Don't let any bone head drink anything in your car.
Old Jul 2, 2005 | 07:50 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Under the seat it is!
The mounting has to be level - not flat. Make sure that its tightly mounted so that it doesn't bounce around or vibrate on it's own.
Old Jul 3, 2005 | 05:51 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Can you someone confirm that you can listen to a CD and watch do NAV at the same time? Someone at best buy told me you couldnt play a CD and do NAV simultanously...but that sounds preposterous to me.....what would the point be?
Also, is the entire NAV map loaded into the memory? Or do you have to switch to the NAV CD when plotting a destination.
Thanks!
Old Jul 3, 2005 | 07:05 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The AVIC N2 has an internal memory storage for a limited amount of navigation. Once you run a route you can pop the DVD disk out and play an MP3 or audio CD. If you stray off your route too far you'll wander off the map and need to put the nav DVD back in.
I think I've solved that problem with a 6 CD changer that I'm going to mount aft.
Old Jul 3, 2005 | 11:17 PM
Sharif@Forged
Forged Performance
OK, that sounds exactly like the N1 that I currently have. I am thinking of upgrading, but just want to make sure I am not giving up any features.
