Bose Audio Pilot Testing Update
Old Dec 7, 2002 | 11:42 AM
jelledge's Avatar
jelledge
Default Bose Audio Pilot Testing Update
Guys,
I spent this morning investigating the Bose Audio Pilot system and trying to improve the sound quality. I HAVE had my amplifier replaced as per the TSB. This did fix the boomy bass problem with the radio but seemed to drastically lower the subwoofer output so as it cannot really even be heard or felt (as opposed to before where the sub really kicked ***)
I set out to see if I could disable the audio pilot micrphone (located under the steering wheel) or possible change something in one of the amplifiers. This was in an effort to get my bass response back.
Okay the short story is this:
I tried unplugging the audio pilot microphone and it had no effect on the sound system on either CD or Radio even after playing for like 5 minutes. Now this is very different then what others had reported when they unplugged the mic (system went crazy) - so I am not sure if this is a result of the new amplifier or I had a bad one?
Anyway - since unplugging the mic had no effect I did not have high hopes for anything else. I measured the resistance of the mic (about 8k ohms) and stuck in a resistor in its place of about the same value. No effect.
Next I tried different resistors ranging from 3k to 10k ohms all had no effect.
I moved onto the subwoofer amp to see if there was any kind of gain adjustment to get my bass back. No dice -- nothing - nada.
Next I removed the main amp that was replaced in the TSB. I took it apart also and did not see anything that I could change. Also I noticed that the entire board was new and was dated in October (my car was built in June-July).
So I guess the short story is that I think we may be out of luck. Maybe the modifications to the audio mic would work better on someone's car were unplgging the mic actually did something. I think I will just have to go aftermarket amps to make the system sound good.
Below I have attached various pics of my journey through the car's stereo system. Enjoy.
Jason
Old Dec 7, 2002 | 11:46 AM
jelledge's Avatar
jelledge
Default Audio Pilot Microphone
Here is the Mic under the steering wheel
Old Dec 7, 2002 | 11:52 AM
jelledge's Avatar
jelledge
Default Close-up of mic
stupid mic
Old Dec 7, 2002 | 11:53 AM
jelledge's Avatar
jelledge
Default microphone pickup
stupid mic
Old Dec 7, 2002 | 12:00 PM
jelledge's Avatar
jelledge
Default SubWooffer
Interesting Design -- Looks good for potential upgrades. Needs more Dyno Matting in the Sub area.
Old Dec 7, 2002 | 12:01 PM
jelledge's Avatar
jelledge
Default Back Of Subwoofer
So so speaker
Old Dec 7, 2002 | 12:02 PM
jelledge's Avatar
jelledge
Default Subwoofer Cavern
Man you could fit a small girl in this area - - it is HUGE
Old Dec 7, 2002 | 12:11 PM
jelledge's Avatar
jelledge
Default Subwoofer amplifier
Not Much to it
Old Dec 7, 2002 | 12:12 PM
jelledge's Avatar
jelledge
Default Subwoofer amp label
Label on the amplifier
Old Dec 7, 2002 | 12:14 PM
jelledge's Avatar
jelledge
Default Main AMP
This is the location of the Main Amp that gets replaced in the TSB
Old Dec 7, 2002 | 12:16 PM
jelledge's Avatar
jelledge
Default Main AMP unveiled
Main AMP
Old Dec 7, 2002 | 12:17 PM
jelledge's Avatar
jelledge
Default Main AMP LAbel
Label on main amp replaced under TSB
Old Dec 7, 2002 | 12:18 PM
jelledge's Avatar
jelledge
Default Guts of main amp
Again not much here --- damn
Old Dec 7, 2002 | 12:19 PM
jelledge's Avatar
jelledge
Default Main Amp Date label
Check out of the board. My car was built like June so this must be an all new board
Old Dec 7, 2002 | 01:10 PM
DrDrilZ's Avatar
DrDrilZ
so after taking your car apart like that, how many leftover pieces did you have after putting it back together?
Old Dec 7, 2002 | 05:26 PM
jelledge's Avatar
jelledge
Default LOL
Yeah really. You know everything was pretty easy except for the rear amp in the hatch. You had to rip half the freakin car apart to get that one out. Hopefully I saved someone else the trouble.
Old Dec 7, 2002 | 08:15 PM
tbob's Avatar
tbob
Is replacing the amps going to fix the problem or is the AudioPilot processing done in the head unit?
Old Dec 8, 2002 | 07:25 AM
tbob's Avatar
tbob
p.s. That was in reply to your last message at:
https://my350z.com/forum/showthread....1&pagenumber=3
We have this going in two threads.
Old Dec 8, 2002 | 08:14 AM
jelledge's Avatar
jelledge
Default Audio Pilot Seems to be from the main amp
I would think since they replaced the main amp as per the TSB that the audio pilot is mainly linked through the amp and not the head unit.
Either way aftermarket amps will give much better flexibility. With new amps you can adjust the gain, crossover points, and bass boost. Overall system control should be quite good.
What I can't figure out is why Nissan chose to put the main amp so far back in the car. I mean the area behind the subwoofer is absolutely huge. They could have mounted half the systems in the car in this area.
Old Dec 8, 2002 | 08:19 AM
Rahtok's Avatar
Rahtok
Does it seem that the Audiopilot thing still works? i.e. does it still boost volume as the ambient noise in the cabin increases?
