Help removing just the Sub woofer
Old Jul 15, 2005 | 01:05 PM
DanOnTheRoad's Avatar
DanOnTheRoad
Default Help removing just the Sub woofer
There is a creaking noise coming from what I think is the sub woofer from my 05 roadster. Another member had the same problem and it went away when he took the sub out and put it back in and refastened the screws.
Is there a non complicated way to remove just the sub? Everything I've found talks about gutting out the entire rear.
Thanks.
Old Jul 15, 2005 | 01:32 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
1. Pry open the subwoofer grill with a flat blade screw driver from the top - just gently work the blade into the gap of the square frame that surounds the speaker grill.
2. Remove the four screws holding the subwoofer.
3. Replace it with something better - I mean look at the thing.
4. Replace screws and cover.
Old Jul 15, 2005 | 01:43 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Yea, if you're gonna go thru that you may as well put a better free-air sub there. It's not that hard...
Old Jul 15, 2005 | 01:54 PM
bcheng4jc's Avatar
bcheng4jc
yea, that sub is made of paper! so cheap! that's bose for you
Old Jul 16, 2005 | 04:41 AM
DanOnTheRoad
OK, got it done last night. I just put a flat blade under the whole plastic cover, and "pop" there she went. Too easy. Tightened the screws (which were lose) and bye bye creaky noise. You don't know how releaved I am. It was driving me insane.
Is there a reasonably priced sub that is a direct bolt on?
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
