Why doesn't basslink come on?
Old Aug 16, 2005 | 03:12 PM
HokieZ's Avatar
HokieZ
Default Why doesn't basslink come on?
If I plug in the RCA's from my new head-unit (Kenwood KDC-x789), the basslink doesn't come on. If I plug in the speaker level input I had been using, it does.
Anybody know how I can get it to come on without using the speaker level inputs. I'm want to run the line from the HU to the sub but am not sure exactly which one to run to it. These are the two that are left:
P.CONT - Power Control wire (blue/white) - When using the optional power amplifier, connect to it's power control terminal.
EXT.AMP.CONT - External amplifier control wire (pink/black) - terminal of the amplifier having the external amp control function.
Thanks,
Old Aug 17, 2005 | 02:17 PM
lightner22's Avatar
lightner22
When you had speaker level inputs i'm guessing you had it set to auto-on. You need to run a turnon wire to the head unit or to the cigarette lighter so it knows when to turn on and off. You can't use auto on with line level inputs
HoBrahYouStink
Jun 24, 2016 10:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Depravity
Oct 1, 2015 04:49 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
