subwoofer bracket and cover part numbers?
Old Aug 21, 2005 | 10:47 AM
cha shu bao's Avatar
cha shu bao
Default subwoofer bracket and cover part numbers?
i was wondering if anyone knows what the specific part numbers are for these parts:
http://www.courtesyparts.com/Merchan...de=28178-Z33SW
http://www.courtesyparts.com/Merchan...de=28163-Z3303
i wanted to pick them up from the nissan dealer, but they told me i needed the specific part number. go figure, i thought they would know better than i did.
also, if anyone has any feedback about putting a sub in that factory section vs. trunk, i'd appreciate it. i figured this would be the most space saving area since nissan had already put it there. anything i should know before trying to install these would be great too. much appreciated.
Old Aug 21, 2005 | 11:26 AM
Endless Shock's Avatar
Endless Shock
Hey I have the stock sub bracket... I dont need it anymore... Let me know how much the dealer says it is and we can make a deal... Im in norcal so shipping would be 2 day ground... Hope that helps...
Old Aug 21, 2005 | 04:36 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
You'll want a "free air" subwoofer vice the more typical one designed for a seal box or ported one.
Old Aug 21, 2005 | 04:50 PM
cha shu bao
thanks. anyone know the part numbers? maybe members that work at a dealer?
Old May 2, 2006 | 04:53 AM
Cambelsoop's Avatar
Cambelsoop
will this bracket fit on the other side of the car?
Old May 2, 2006 | 05:24 AM
sq40's Avatar
sq40
I think all Zs come with the Subwoofer bracket in place, if it has the sub, it gets the grill cover, if it dont, they just put a solid cover over it. You may not need the bracket at all.
Old May 2, 2006 | 08:17 AM
z350boy's Avatar
z350boy
In order to achieve quality sound you will need to build an enclosure for the subs. Do a search on this forum and you will find a schematic showing the dimensions you need. Purchase some MDF board and cut to size, OR you can order a fiberglass enclosure from www.wickedcas.com which is made specifically for our Z. Dynamat is an added plus if done correctly.
Old May 2, 2006 | 08:31 AM
z350boy's Avatar
z350boy
...........................................YES.............. ............
Old May 2, 2006 | 09:10 AM
z350boy's Avatar
z350boy
I had to contact my dealer to check on the progress of Z's maintenance so I took the liberty of asking them the stock part number you were requesting. they told me the part number is 28178-CD001 (grey) & 28178-CD000 (charcoal). Hope this helps. I recommend you take a look at my previous post for additionla info.
Old May 2, 2006 | 09:12 AM
z350boy's Avatar
z350boy
Originally Posted by z350boy
I had to contact my dealer to check on the progress of Z's maintenance so I took the liberty of asking them the stock part number you were requesting. they told me the part number is 28178-CD001 (grey) & 28178-CD000 (charcoal). Hope this helps. I recommend you take a look at my previous post for additional info.
BTW...these part#'s are for the speaker cover panel. The sub bracket part# is 28163-CD003.
kyin
Oct 15, 2015 05:54 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
