sup box question??
to anyone who knows lots bout audio....i was planning to get the sub box from ebay that sits right under the strut bar...the box interior has a .75 cubic feet..is that enough airspace for 2 JL 10w3v2 subs..?
http://cgi.ebay.com/Nissan-350z-Cust...QQcmdZViewItem
thanks
thanks
Mike (the seller is a great guy)... The box has excellent fitment... For the subs you want to have 0.625 - 0.75 per chamber... I could be wrong Im just going by what it says on the spec sheet... I have a one enclosure for a single 10W6V2 and it sounds great... I hope that helps...
not the answer i was looking for...reguardless if its 1 sub or 2 sub its still .75 cubic ft....just wondering if 2 subs with .75 cubic ft enclosure..would the sound quality be any different because the enclosure is smaller
They'll work but the Qtc is going to be a bit on the boomy side following the purple curve in the graph below. This might be a sound you are looking for. The 10W6V2 would be a better match with a flater response and lower bass frequencies. This chart is based on two woofers - one woofer is going to have a different sound.
I just ran the math and did NOT see if they would physcially fit inside the box. My Infinity 10.1dVQ's are 6 inches deep and just barely fit as they rub against the sides - not the back.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
