Questions about which sub I should go w/
Old Aug 31, 2005 | 10:36 AM
platinum350's Avatar
platinum350
Default Questions about which sub I should go w/
I am having a hard time deciding which subs to go w/. I have decided to go w/ an Zenclosure from Mike. I am trying to keep price down for now but doesn't mean later down the road I am not going to upgrade.
I have a brand new Sony x-plod amp(which I know isn't the best) rated at 1000 watts peak which is probably around 450 RMS. I also have 2 pioneer subs which require about 1.0 Cu. airspace and Mikes Zenclosure only offers max of .75. So, if I wanted to install those subs in an ZE, im assuming the bass will be very tight but not boomy at all? If I did that, would I want to use just one of the subs or both?
Or, I was thinking about getting just ONE MBQ PWE-252 10'' sub.
Below are the specs on that sub:
Details:
» 10" subwoofer with two 2-ohm voice coils
» treated paper cone with polypropylene dustcap and inverted Santoprene surround
» cast-alloy basket
» power handling: 400 RMS watts (200 watts per voice coil)
» frequency range: 22-300 Hz
» sensitivity: 90 dB
» mounting depth: 5-7/8"
» sealed box volume: 0.75 cu. ft.
» Recommended Q-Logic Box Type: 1
» warranty: 3 years
However, I do want some good bass. I don't know if by just getting a box to accomodate just the one MBQ if im limiting myself to adding another sub later on.
Im curious to know what would sound better, the 2 pioneer's or the one MBQ.
I have a hunch the MBQ would be the winner.
Thanks for anyhelp w/ this!
Old Aug 31, 2005 | 10:50 AM
Endless Shock's Avatar
Endless Shock
Old Aug 31, 2005 | 12:01 PM
ANXIOUZ's Avatar
ANXIOUZ
Which sounds "better"? You'd get more boom with 2 10's and more clarity with the single 10 IMO. I have a single Type-R 10" and depending on how I tune the amp, it's a beast. I can't even imagine 2 10's.
Old Aug 31, 2005 | 04:35 PM
NisAznMonk's Avatar
NisAznMonk
Stick with your Pioneers for now and add a bit of polyfill if you need it. For what you are running, the missing 0.25ft³ won't be very noticeable to the ears. If you feel you do need some polyfill though, just go to your local walmart (or whatever you have similar) and buy a cheap pillow. One pillow should have enough in there for both subs. No point in changing out subs until you tried your Pioneers out.
Now if you REALLY want to get subs that will fit perfect in that tight of an enclosure, look into the Peerless XLS subwoofer. They are about $175 shipped each, and the 10" can go in as little as 0.4ft³ and the 12" can go in something as small as 0.6ft³.
Old Aug 31, 2005 | 04:39 PM
platinum350
Thanx guys, think im going to just stick w/ the 2 Pioneers for now. I am not looking for anything too crazy. I can always upgrade later!!!
Old Sep 4, 2005 | 09:22 AM
james840a's Avatar
james840a
I just got a Alpine 10" Type-R power handling is 500w rms, 1500w peak. Optimum sealed box is .65cu ft. box volumn range .5min-.8max cu.ft.
Old Sep 4, 2005 | 08:14 PM
platinum350
Hey james, hows your box working out for ya? I imagine that sub would produce some hard hitting basss, yours is facing up right?
Old Sep 4, 2005 | 08:38 PM
james840a's Avatar
james840a
Hi, i havent been able to install it yet. Havent gotten my car back from the repair shop. I was to get it friday, but the little side window didnt come in tell late friday
But once i get it in ill let you know how it sounds.
Mine is facing up. Was thinking about haveing the magnet side out.
Old Sep 4, 2005 | 09:53 PM
platinum350
I have always been curious, is there any advantage/disadvantage(other than looks) to having the magnet side facing out?
Old Sep 5, 2005 | 07:16 AM
james840a's Avatar
james840a
You know thats a good questions. I dont think there is a defferance other then looks. But i could be wrong.
Old Sep 5, 2005 | 09:06 AM
vkzawa's Avatar
vkzawa
Could it maybe be if there isn't enough mounting depth, but plenty of air space?
Old Sep 7, 2005 | 05:32 AM
Nazar's Avatar
Nazar
Details:
» cast-alloy basket
» warranty: 3 years
How about some fiberglass enclosures with enough room for up to a 10w7. And they sit flush with strut tower bar front and rear.
Here is a link http://www.wickedcas.com/gallery/cat...s.php?cat_id=6
Old Sep 7, 2005 | 09:33 AM
platinum350
What are your prices onthese boxes...I saw the different ones but no price.
Thanks.
Old Sep 7, 2005 | 09:42 AM
Nazar's Avatar
Nazar
Thanks.
Thy start at $299.95 and Up. Depending on which one.
Old Sep 7, 2005 | 09:53 AM
platinum350
what about the one under the strut bar that fits 2 10's? How do they come, vinyl,carpet or painted?
Old Sep 7, 2005 | 10:47 AM
Nazar's Avatar
Nazar
2x10 Box is $349.95
With Vinyl $449.95
Old Sep 7, 2005 | 12:54 PM
SkiTTlez's Avatar
SkiTTlez
well i went with the MB Quart reference 10 in a custom box i built in FRONT of the strut bar with sub facing rear. only i built it ported and it is a monster but sh*thouse does it hit.
Old Sep 7, 2005 | 05:30 PM
platinum350
What's shipping to 19063. Also, what's the air space in this box?
Old Sep 8, 2005 | 05:57 AM
Nazar's Avatar
Nazar
http://www.wickedcas.com/store/produ...39bc948ce327f0
This will give you a better idea.
Old Sep 8, 2005 | 06:26 PM
platinum350
Those vinyl wrapped door pods.........very sweet. Can you do any better on the price?
