Pioneer AVIC-D1 with 2005 G35 Double Din Conv. (PICS)
Old Sep 14, 2005 | 07:10 AM
BlackCoupeG35's Avatar
BlackCoupeG35
Default Pioneer AVIC-D1 with 2005 G35 Double Din Conv. (PICS)
Old Sep 14, 2005 | 07:11 AM
BlackCoupeG35
Here is the factory 2005 XM tuner.
I was able to use my factory pre-installed antenna with my Pioneer XM tuner.
This antenna is supposed to be better than any aftermarket antenna since its connected to the frame of the car.
I mounted the GPS antenna on the right corner of the dash.
I cut down my trim piece with 100 grit sandpaper to get the perfect fit.
Rockford amp which will power 2 Rockford subs.
I know I dont have any trunk space, but I never use my trunk anyway's.
Old Sep 14, 2005 | 07:12 AM
BlackCoupeG35
I got the remote bass control for my Rockford Fosgate amp to fit in the ashtray!!
Old Sep 14, 2005 | 07:13 AM
BlackCoupeG35
Secret hack on how to bypass the GYRO lock. You can now watch video and operate NAV while driving:
_______________________________________________
Hopefully you didn't use every wire on the Pioneer wire harness. Find the wire you didn't use, and just pull it out of the harness.
I used the auto mute lead wire. After you pull it out, you will see that the wire has a connector on the end like this...
There is 1 empty slot on the harness next to the ground wire.
Insert this wire into that slot. You should feel it "click" into place...
Ground this wire and the E-brake wire and you're good to go!!
Old Sep 14, 2005 | 07:14 AM
mrbader's Avatar
mrbader
Are they making an install kit for the G35 now that replaces the oem that has all the buttons cut out on it? What install kit is it?
Old Sep 14, 2005 | 07:21 AM
imtiaz's Avatar
imtiaz
holllllllllllyyyyy snapz, D1 cracked ? is that an actual dvd playing ? i thought they werent even able to play dvd's at all ? just dvd-rom that were meant for pcs only and not a dvd that would work in a regular dvd player? ..
also is that deck detachable face ?
Old Sep 14, 2005 | 07:49 AM
THEDUKE's Avatar
THEDUKE
You still need an external DVD player. The lockout bypass is just to let you watch video while driving. The lockout bypass will not make it play DVD movies.
Old Sep 14, 2005 | 08:04 AM
imtiaz's Avatar
imtiaz
so what you're saying is, you cant put a regular dvd into slot 2 where the nav dvd goes ?
Old Sep 14, 2005 | 01:17 PM
CompiledMonkey's Avatar
CompiledMonkey
Very clean looking install. Exactly what I'm looking for.
Old Sep 14, 2005 | 05:32 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
did you install all these by yourself or shop? nice setup!
Old Sep 14, 2005 | 05:34 PM
CompiledMonkey
Looks like he did the install.
Old Sep 15, 2005 | 10:22 AM
BlackCoupeG35
This is the OEM dash and A/C controller for the Nissan Skyline. I had to special order it from Nissan Japan.
Old Sep 15, 2005 | 10:24 AM
BlackCoupeG35
Thanks guys, yeah I installed everything myself....
Old Sep 15, 2005 | 10:54 AM
JimRHIT's Avatar
JimRHIT
Great installation....VERY clean. I don't like the subs in the trunk idea ... but its useless otherwise anyways, lol, so why not
So did that trim piece that you sanded come with the Double Din conversion?
I ask because I just recieved my D1 yesterday, and I am going to need a trim piece for my Z.
Please let me know of the name brand and where you bought it, if it didn't come with the kit.
Thanks man,
Jim
Old Sep 15, 2005 | 12:55 PM
JimRHIT's Avatar
JimRHIT
nm ... I just opened the box and realized it came inside the box im retarded
Old Sep 15, 2005 | 09:08 PM
NisAznMonk's Avatar
NisAznMonk
were there any problems converting to the G35 buttons?
Old Sep 15, 2005 | 10:21 PM
B-Unit's Avatar
B-Unit
that sub box is farr to big, the screen is nice tho.
Old Sep 18, 2005 | 09:31 AM
jcrdr's Avatar
jcrdr
hey does any1 kno if switching around the wires like that for the n2 (to watch the dvds while driving) will cause the unit to read "mechanism error" and not feed my discs in OR out!!!!???????? i installed yesterday and switched my wires around yesterday to "trick" the brain......but the dam unit wont take my discs!!!!!!!!! does any1 kno if its due to the wiring....or is it sumthing totally different???????
Old Nov 2, 2005 | 04:49 AM
BlackCoupeG35
it wont work for the n2...
Old Feb 5, 2006 | 11:24 PM
XBS's Avatar
XBS
Veteran
very nice looks PIMP!
