SAT antenna placement and SAT install
Old Sep 22, 2005 | 09:26 AM
Cambelsoop's Avatar
Cambelsoop
Default SAT antenna placement and SAT install
wassup... i need some opinons on where to place the Serius antenna. i just bought the eclipse AVN5435 and the serius tuner will be installing early next week
i was wondering in ne 1 had installed the SAt tuner eithe rto their eclipse or another HU that uses a SAt interface.
where did u place the actual tuner?
where did u place the antenna,? i dont want it to look like ****. and i absolutly love the body lines on my SB ZR and dont wanna ruin it...
thank you in advance for your help
Old Sep 22, 2005 | 10:47 AM
Cambelsoop's Avatar
Cambelsoop
Also where did u put your GPS antenna.
Old Sep 22, 2005 | 11:55 AM
jcastino's Avatar
jcastino
Can't you plug the antenna wire into the built in antenna in the windshield?
Old Sep 22, 2005 | 05:11 PM
Cambelsoop's Avatar
Cambelsoop
i dont kno can u ? um what antena in the windshield?
Old Sep 22, 2005 | 05:23 PM
jlimquest's Avatar
jlimquest
Placed mine in the nav cubby. Ant on the roof w/ 2 inch tail.
Attached Thumbnails SAT antenna placement and SAT install-dscn0825-medium-.jpg   SAT antenna placement and SAT install-dscn1103-medium-.jpg   SAT antenna placement and SAT install-rscn1146-medium-.jpg
Old Sep 23, 2005 | 08:01 AM
JLU's Avatar
JLU
No you can't use a stock antenna... you need the satellite antenna. JLIMQUEST's placement is probably best. It depends on where you live and if they have terrestrial antennas or not. If so, you may be able to place it inside.. otherwise, it should go on the roof.
Old Sep 23, 2005 | 08:23 AM
bixby's Avatar
bixby
Both, my GPS and Sat antenna's are on that small flat strip in the middle of the dash. I have the Pioneer systems and both antennas are very small.
I get a little "cut out" on the SAT radio from time to time but I much prefer the stealth over having something stuck to my roof.
Old Sep 23, 2005 | 11:18 AM
dmh350z's Avatar
dmh350z
Had my sirius antenna installed in the hatch brakelight, no problems w/reception.
Old Sep 23, 2005 | 11:25 AM
dmh350z's Avatar
dmh350z
Old Sep 26, 2005 | 04:59 AM
Cambelsoop's Avatar
Cambelsoop
no one else with a roadster intaleed SAT i really do not want the atenna ont he outside of the car...
Old Sep 26, 2005 | 11:13 AM
nissan350zfan's Avatar
nissan350zfan
Do a search. I have previously posted about my SAT Antenna install in the location for the stock GPS antenna, under the driver side upper dash cover. Of course if you have NAV this spot will not be available.
Old Sep 26, 2005 | 11:43 AM
R2theP's Avatar
R2theP
Same Spot for me also, Does not cut out enough to make it an issue.
I hid my Sirius tuner for my ddx-7015 behind the panel behind the drivers seat, theres alot of room back there.
Old Oct 6, 2005 | 08:14 PM
Cambelsoop's Avatar
Cambelsoop
where is this space. and how do i get to it?... can i put the gps and the serius tuner there?
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
