question about box design for you audio pros
Old Dec 24, 2002 | 02:03 PM
imntcrzy's Avatar
imntcrzy
Default question about box design for you audio pros
I am trying to figure out a sub box design for my 350. I will be using 2 11" focals subs. Each requires a minimum of 1.1 cu ft. I can make a box with 2 sealed chambers of 1.1 each but the box won't fit under the strut area. Will there be a problem of using both subs in 1 sealed chamber of about 2 cu ft. I really want to be able to fine tune the sub, probably will use xtant parametric eq or audiocontrol. I know that home audio sound is almost impossible in a car but I would like to get as close as possible to it.
thanks
Old Dec 24, 2002 | 04:08 PM
jeffa's Avatar
jeffa
You can use the subs in a sealed enclosure with a common airspace. It will not affect the performance of the subs. Make sure that the box is well sealed, and at least lined with polyfill to reduce standing waves inside the box.
Old Dec 24, 2002 | 04:23 PM
imntcrzy's Avatar
imntcrzy
the problem is one wall of the box will be plexi..... so I don't want to use polyfill. do you think using no fill will be ok. The box will be fiberglass and gel coated
Old Dec 24, 2002 | 05:48 PM
jeffa's Avatar
jeffa
I have built boxes with and without fill. You will be OK with the box you are planning to build without the fiberfill...
Old Dec 24, 2002 | 09:27 PM
srobert910's Avatar
srobert910
From what i understand, All focal subs are suggested in a vented enclosure only. I don't know how they would perform in a sealed enviroment.
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
