350Z 2003 ICE project
Old Oct 13, 2005 | 01:00 PM
Cuore_alfa's Avatar
Cuore_alfa
Default 350Z 2003 ICE project
1- front and rear camera
2- front and rear park sensors
3- 5.8" TFT LCD monitor
4- DVD player
my OEM audio is the bose 6cd whit tape, i have figure out how to install the most of the parts described above, but need some tips to hook the DVD audio to the bose radio, any input will be welcome, cheers!
Old Oct 21, 2005 | 03:22 PM
Cuore_alfa's Avatar
Cuore_alfa
The Soundgate AUXNISSv2 from www.discountcarstereo.com will be used to manage the DVD audio in the HU
Now i have to figure out where to drill the holes for the front/rear backup sensors and front/rear camera.
P.S. i just install the 3000K D2S xenon bulbs, they look great! rich nice yellow color output.
Old Oct 25, 2005 | 07:29 PM
Cuore_alfa's Avatar
Cuore_alfa
Done, i wont put any DIY since nobody reply to my thread :sad:
Old Oct 25, 2005 | 07:30 PM
Cuore_alfa's Avatar
Cuore_alfa
next step, lead the wires to the cockpit, any input?
Old Oct 25, 2005 | 07:38 PM
skip2daZ's Avatar
skip2daZ
great work man, how come you need a cam for the front though?
Old Oct 25, 2005 | 08:52 PM
jakedajewel's Avatar
jakedajewel
maybe he's too short...LOL..jk
Old Oct 26, 2005 | 03:42 AM
Cuore_alfa's Avatar
Cuore_alfa
nhaa 6'1" here ...the front cam is just for pimp
Old Oct 26, 2005 | 06:20 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I'm planning on adding a camera up front too to give me something to watch on the second monitor while driving other than DVD movie re-runs!
There's plenty of room to pass through cables on the passenger side behind the battery. You have to remove the battery trim piece but once you do you can look down into the gap behind the battery and see that area pretty well. I try to avoid the driver's side as there's enough factory wires there with the BCM module and fuse boxes to make it a mess.
Old Oct 26, 2005 | 08:07 AM
n666's Avatar
n666
i'm interested in the DIY for the rear camera...
which camera did you get? does it automatically turn on when you back up?
Old Oct 26, 2005 | 12:53 PM
Cuore_alfa's Avatar
Cuore_alfa
n666, i get them on ebay, search for "rear view camera"
SPECIFICATION:
TV SYSTEM: PAL/NTSC
IMAGE SENSOR:1/3 Inch CMOS Image Sensor
CMOS TOTLE PIXELS: 510*492(NTSC) 628**582(PAL)
RESOLUTION :380 TVL(Enhanced)
Auto Electronic Exposure:1/60~1/15000 sec
MINILLUMINATION(3000K): 3Lux/f1.2
White Balance: Auto
Increment Control: Auto
VIDEO OUTPUT : 1Vp-p75
S/N Ratio : >48DB
Lens View Angles: 56
Storage Temperature: -10 to 60
Working Temperture : -10 to 45
POWER SUPPLY DC12V
Power current: Max: DC500MA
Weight: Approx 65g
Cable: Standard 30CM RCA/DC jack
you can take the reverse lamp wires to activate it when you engage the reverse, however i will take another route
Right now i have the center console off to install the screen and the AUXNISSv2, i choose the FARENHEIT T-7000MHR TFT LCD since it look like OEM, props to this thread:
FARENHEIT T-7000MHR INSTALL
https://my350z.com/forum/showthread....ight=FARENHEIT
now, wiring...
Old Oct 26, 2005 | 01:37 PM
james840a's Avatar
james840a
wow your brave to drill holes in your front bumber. Good job.
Me i think i would have mounted the cam in the grill area.
Old Oct 26, 2005 | 05:13 PM
Cuore_alfa's Avatar
Cuore_alfa
i check several spots of the grill, but in the end the best bet was the area below the nissan decal, since the grill suck too much air/bugs and bugs mean dirty lense
pics of the center console ready to the Farenheit T-7000MHR
Old Oct 27, 2005 | 05:40 AM
umzzz's Avatar
umzzz
Cwest Army
if you can record using that front camera...you could make some pretty wicked videos!
Old Oct 27, 2005 | 02:21 PM
Cuore_alfa's Avatar
Cuore_alfa
umzzz: all what i need is a output video wire, pretty easy and a microphone near to the exhaust
anyway heres the update:
Leds Backup Sensor display
there is no room inside the mirror to install this display :sad: but this don`t look that bad...
The display show the distance from 0 to 1.3 meters and you can see in bars (green to red) wich is the closer side Left or Right
Old Nov 12, 2005 | 07:26 AM
Cuore_alfa's Avatar
Cuore_alfa
The DVD player is not here yet, the Farenheit T-7000MHR looks OEM, i custom made a switch to change the 3 video source (Front Camera - DVD - Rear Camera), hold a sec. for pics
Old Nov 13, 2005 | 10:31 AM
NYC_G35C's Avatar
NYC_G35C
does the unit beep also when you're close to an object? and, if so, can you turn off the beeping? how accurate are the backup sensors?
that display unit looks like it fits perfect on top of the mirror... can you see it from outside the car?
Old Dec 7, 2005 | 07:42 AM
Cuore_alfa's Avatar
Cuore_alfa
NYC_G35C, yes it have a sound advice, i also install a switch to turn on/off the sound:
The Round switch is for the video input: Left (front camera), Center (DVD) and Right (rear camera).
The PCD Display in action (this thing look OEM)
Rear View camera (not HDTV, but i can live whit that )
Front view camera
Rear Zed view
i`m wating for the DVD player, cheers!
Old Dec 20, 2005 | 02:32 PM
Cuore_alfa's Avatar
Cuore_alfa
Soundgate AUXNISSv2
HOW IT WORK
1) Turn on the radio and select the CD6 Input
2) Press the CD6 once again and the display will show
3) afther a few seconds (2 or 3) the display change to
And the audio input is ready
To change to the CD6 CDs just press once the CD6 function and the last CD played will return to sound
Also i upgrade the Video switch for this one, Get the idea from the LR3 and the BMW i-drive :P
Still wating for the damn DVD player...
Old Dec 20, 2005 | 03:17 PM
stl350's Avatar
stl350
nice, thanks for the pics and write up.
Old Dec 23, 2005 | 12:49 PM
nicolaycastro's Avatar
nicolaycastro
Great customization!
Is there a way you can only get and install the rear parking sensors, without the cameras or a screen?
If so, where can I buy them, and what do I need to buy?
