Bose High Amp?
Old Dec 31, 2002 | 10:51 AM
NittoZ's Avatar
NittoZ
Charter Member #65
Default Bose High Amp?
Ok..before you flame, I searched. Where is the factory high range amp for the bose system located? Someone help!
NittoZ
Old Jan 1, 2003 | 09:29 AM
Desmo's Avatar
Desmo
The amp for the four corners is located in the driver's side rear of the car, under the black styrofoam piece that is the floor of your hatch area. You have to remove a few plastic pieces before you can remove the styrofoam piece, but it's not too hard. The main amp is bolted to a metal frame that is in turn bolted to the car.
The sub amp is located right next to the sub; bolted to the metal panel that the sub is mounted on.
JL
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
