DD INSTALL help???
Old Dec 6, 2005 | 07:07 PM
futbol333's Avatar
futbol333
Default DD INSTALL help???
I posted this on G35 Driver and the guy answered but now its down and i can get to it...someone please help...on my double din tv/dvd/cd etc lcd the sound for the radio is working but not for the dvd or cd....whats wrong please help?
thanks
-Cameron
Old Dec 6, 2005 | 10:20 PM
Tyler's Avatar
Tyler
Did it work before? Are any aftermarket or OEM amps being used?
If there are amps being used, sounds like someone hooked up the power antenna lead instead of the remote turn on lead. Hence, you switch from radio to CD, the antenna goes down and your amps turn off.
Old Dec 6, 2005 | 10:23 PM
Inovashn's Avatar
Inovashn
+1 to wrong lead. Hey cameron if you still have problems tommorrow call me and i'll check it out.
Old Dec 9, 2005 | 11:38 AM
808_FairladyZ's Avatar
808_FairladyZ
+1, if you use the solid blue power antenna turn on lead then your amps will go on only when your tuner is on. Use the blue w/h white stripe wire which is your amp turn on wire.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
