Polk Audio DB650 without spacers or mod?
Old Dec 9, 2005 | 01:55 PM
milkit's Avatar
milkit
Default Polk Audio DB650 without spacers or mod?
Just ordered 2 pairs Polk Audio DB650 6.5" 2-Way Coxial Speakers
Anyone have these? Will i need to modify anything or use any spacers for them to fit properly?
Old Dec 9, 2005 | 05:23 PM
dannichols's Avatar
dannichols
The window rolled down is only about an inch back inside the hole. Unless you have very shallow speakers I don't see how people are getting by without using a spacer..at least the one that normally comes with the speaker. For people that aren't using any spacer with an aftermarket set, I would question where the window is when rolled down for you..it may be between the magnet and the basket.
Old Dec 9, 2005 | 06:32 PM
idrmofs7's Avatar
idrmofs7
where the hell would i get a spacer? i got some speakers but need a spacer for them to work! thanks
Old Dec 9, 2005 | 07:15 PM
Inovashn's Avatar
Inovashn
try your local Best Buy or order them online.
http://www.hmaster.com/info.php?Item=B0002BG6QY
Old Dec 9, 2005 | 10:12 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Or
I installed my polk separates using the stock speakers as a spacer. It's so easy it's not even funny. It takes about a minute to cut out the old speaker from the basket using diagonal cutting pliers. Then use silicone to seal the speaker to your new spacer and use some to seal up the old wire hole.
Chris
Old Dec 9, 2005 | 11:52 PM
dannichols's Avatar
dannichols
Yes the stocks work just fine. I have some spare MDF spacers I made..You can have for free if you want
Old Dec 7, 2006 | 03:49 PM
geomark's Avatar
geomark
So, were u able to get those db650's in the speaker holes behind the seat? Crutchfield says it wont fit.
Old Dec 7, 2006 | 04:12 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
you should ge thtem behind the seat, considering i have done ifninity kappas behind there with no problem...
on a side note, DLS ultiamte speakrse are of the very few that can fit int he stock location WITHOUT a spacer or anyhting haha...but then again, i dont put anyhting in that location to begin with
Old Dec 7, 2006 | 06:13 PM
bdahern's Avatar
bdahern
You won't be able to get them behind the seat unless you can get some sort of bracket to hold them - they are too small and there is no brackets included with the speakers. I know because I bought a pair from Circuit City and they did not fit. I returned them and got a pair of Infinity Reference 6012i from Best Buy and they fit perfectly - didn't need the including brackets or anything.
Old Dec 8, 2006 | 08:43 PM
dannichols's Avatar
dannichols
I fit a set of PG Ti Elites using only 1/2" spacer. They work very well too. Too bad PG doesn't make them anymore..too bad PG went so down hill :-(
Old Dec 9, 2006 | 07:25 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
forget the elites, just go to where PG buys them instead and buy the morel stuff
Old Dec 9, 2006 | 01:52 PM
dannichols's Avatar
dannichols
I wish.. Anyway, they are both very shallow speakers that offer good midbass. Two things we need in the Z.
Old Dec 9, 2006 | 04:53 PM
first350's Avatar
first350
another place to buy spacers is from ZEnclosures. I got their spacers and they fit perfectly.
-Peter
Old Dec 18, 2006 | 07:21 AM
savvy's Avatar
savvy
what kind of speaker depth are we looking at to be able to fit into stock locations? I am looking at a set of Focals that have a 4 inch moutning depth.
Old Dec 18, 2006 | 10:25 PM
DCroz's Avatar
DCroz
I just put them in my car yesterday. Used spacers from CC for the front and the rears fit fine without spacers. I put in the Jensen 9021 about two weeks ago also. It sounds MUCH better now.
Tochigi_236
Sep 27, 2015 03:40 PM
