What wiring harness?
Old Dec 15, 2005 | 12:27 PM
Mendy9677's Avatar
Mendy9677
Default What wiring harness?
For all you electronic gurus, what kind of wiring harness would I need to have the below headunit installed in the Z?
http://cgi.ebay.com/E244-6-5-TFT-LCD...QQcmdZViewItem
Old Dec 15, 2005 | 08:53 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The standard Crutchfield one will get you started but if you've got the Bose amplifier you're going to need to by-pass or adapt the speaker levels down to line level.
Old Dec 16, 2005 | 11:29 PM
808_FairladyZ's Avatar
808_FairladyZ
Scosche makes an harness part # NNO3B for 350Z. Install kits are also available from this company but does not support a double din install. If your interested in a double din unit, look into the Metra kits for the 350Z. Paul is right. If you do have a Bose System (Changing your system is deffinately understanded), then a bypass is in order.
350Z_Al
Oct 29, 2020 07:44 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
