Distortion problem
Old Jan 1, 2006 | 08:32 PM
Tzuten's Avatar
Tzuten
Default Distortion problem
Hey all,
I'm not a big audio guru, but I went ahead and installed my own system. Went fairly well, but I seem to have run into an issue. Here is my setup:
Infinity Kappa 6.5 components in the front
Pioneer 2 ways in the rear
Rockford 4 channel amp
14 and 16 gauge speaker wire
I am having a bit of distortion when the music is going. A slight hiss or static. I have messed with the gains but still no go.. Does not matter if the car is stopped or in motion. It's barely noticeable but it still bothers me. I do not have the RCAs running near the amp cable. What could be causing the problem? Poor grounding? Thanks!
Old Jan 2, 2006 | 07:29 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Hiss or static - two different sounds/issues/cures.
Could the problem be coming from the source?
Old Jan 2, 2006 | 07:39 AM
momo 350z's Avatar
momo 350z
check your rca's cables,i had the same problem spent hrs trying to find the problem and all it was is that the rca came loose,so hopefuly you might have a simple problem also
Old Jan 2, 2006 | 08:24 AM
Tzuten's Avatar
Tzuten
I'd describe it more as static. And it is not constant. Oh and the headunit is a AVIC-N2
Old Jan 2, 2006 | 09:42 AM
barthelb's Avatar
barthelb
Master
could be a few things. But in my other cars i had we did 2 things to keep it distortion free and clean.
1) you need to seperate your channels. Either by having 2 amps or a crossover.
2) Then you can apply resistors on you highs to remove all bass and mid level frequencies.
then on your mids you can remove some high frequencies to only allow mid level frequencies.
other than that maybe a gain is too high or a bad ground.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
