lilliput non vga screen and xbox
Old Jan 15, 2006 | 07:52 AM
smellslikecurry's Avatar
smellslikecurry
Default lilliput non vga screen and xbox
hey guys i just started installing a screen and xbox in my Z and i have a few questions
1) I powered my screen by running the pos and ground wires to the rear cigg lighter. I also plugged in my power inverter into the same socket. Is this ok to do or is it bad for the car?
2) Can i hardwire the inverter inline into the rear cig with the screen?
3)I havent put in any fuses yet and what fuses should i use for the power interver and the screen.
ill have pics up soon
Old Jan 15, 2006 | 08:55 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The rear power outlet will run a few amps. If your power inverter is just for your Xbox which draws just a few amps you'll do fine. Worst thing that you'll do is pop the factory fuse.
The screen probably draws less than an amp. The inverter depends on how big it is - 80 watts or 300 watts - big difference. Watts divided by volts (13.6) = amps. You can hardwire everything but then I would recommend running a cable from the battery, to a fuse, through the firewall, and then to the back area.
Old Jan 15, 2006 | 10:18 PM
smellslikecurry
thanks paul...its a 200watt inverter that will only power my xbox
ill try and wire it all up and see if the fuse blows if not then
also i have a fm modulater thats powered by 2 aaa batteries...is there a way to hard wire that to the cig lighter?
Old Jan 16, 2006 | 08:20 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Look at your Xbox to see what it needs. The 200w inverter is going to put out as much as the Xbox needs which is going to be closer to 100 watts, may be less.
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
alphared
Nov 14, 2002 12:43 AM
InternetABYSS
Jul 17, 2002 07:07 PM
