rear view mirror problem from stereo install..
I recently installed a new head unit, amps, everything. My problem: my rear view mirrors dont work from the drivers side button. Yes, I've taken both door panels off, all clips are plugged in. I've also checked the wire harness that goes through the body that you put the speaker wires through. My question is, is there a clip or something in the center console behind the head unit that I could have unclipped? I havent checked there yet, because its a pain to undo if theres not. Fuses are good. Cant figure out what it could be, help would be appreciated, thanks....
Originally Posted by Bubble
is your car still under warranty? bring it to the dealer. The problem might be from your mirror itself.
FWIW my washer fluid wasn't working after my stereo install.
Reason: the installer snapped the plastic fastener on the fluid tubing when attaching the amp to the battery. ::shakes head::
I suspect you might have a similar situation where a cable is crimped or got partially cut when doing the install. For it to stop working only after the install, I suspect something happened...not just a bad mirror motor or whatever.
Thanks guys for the suggestions, I guess I'll take it in soon. Its still under warranty, so they should fix it. My only problem with that, when they rip the car apart, it never goes back together the same way I like it. Plus, no telling what they'll do to the new system...
08-06-2021 06:19 AM
