pac aai-nis2 install question
Quick question on the Pac AAI-nis: I am using this to connect my Sirius S50 to avoid the FM Modulator, to an '04 w/ Bose. My S50 uses power from the Cig. lighter, which is converted to 5 volts. Will I fry my S50 if i connect the blue / black wire, or can i use the pac without hooking up the blue / black wire? The Pac has two wires that I don't see myself using, this one and the yellow steering wheel output. Can anyone tell me what the blue / black is for? (this might have been a red wire on the old pac product.) Any help would be greatly appreciated. Thanks
the AAI-NIS has nothing to do with the power being supplied to the S50. power the S50 normally, and only the audio outputs plug into the AAI-NIS
the only thing the AAI-NIS has is a negative output when you select the AUX input. you could use this to control a relay to power on the S50, but i don't think you can directly use it to power the S50
m_0g
Jun 3, 2021 10:05 AM
Workshop12
Mar 23, 2020 01:45 PM
