Need Help ASAP... please
Old Feb 24, 2006 | 01:13 PM
Kabs's Avatar
Kabs
Default Need Help ASAP... please
My headunit has an option of doing 40W or 60W output
Now on the wire it says: WHEN USING THIS UNIT AT 60w SETTING, CONNECT ONLY TO ACC LINE OF 10A OR MORE.
What does this mean? All i want to know is if I can use the 60W mode.
Thanks
Old Feb 24, 2006 | 01:29 PM
Cannysage's Avatar
Cannysage
you should use 40w. you'll get cleaner sound. 60w may distor the sound quality and noise level will be higher.
Old Feb 24, 2006 | 01:37 PM
Kabs's Avatar
Kabs
i have aftermarket speakers if that helps.... previous owner had a kickass system so i think the wiring is new too....
plus the 60W will make it go louder correct? I just dont want to fry anything
Old Feb 24, 2006 | 01:42 PM
MIAPLAYA's Avatar
MIAPLAYA
What its saying is that if you want to run in 60 watt mode the power wire must have at least a 10 A rating. In other words if the fuse on the other end of that wire is 5 A you are going to blow it.
silents1ick
South East Marketplace
Apr 29, 2013 09:19 AM
350zchitown
Jul 2, 2012 02:59 PM
chickmagnet
Southern California
57
Jul 3, 2006 05:49 PM
