Question about ohms...
Old Mar 6, 2006 | 06:42 PM
Kabs's Avatar
Kabs
Default Question about ohms...
Sorry guys for all these questions. Right before purchasing I got warned by a friend about ohms.
My speakers are supposedly 4ohms, the subs I want to purchase are 2 ohms and the amps can be at 2 or 4 ohms... but i want to keep it at 2 ohms since the power output is greater (420w vs 210)
Can you mix speakers of different ohms with subs? Im sorry if im not making any sense... cuase its really not making any sense to me. I dont understand how resistance can blow my speakers =\ or if it will....
Old Mar 6, 2006 | 06:59 PM
pushing4wardbac's Avatar
pushing4wardbac
Equivalent Resistance(in series) = (R1+R2)
Equivalent Resistance(in parallel) = (1/r1 + 1/r2 )^-1
Yes a 2 ohm and a 4 ohm speaker can be used together with no ramifications
to get closer to 2 ohms you could use a 8ohm and a 2ohm to get a equivalent resistance of 1.6ohm.
1.3 ohms would be the resistance if you put a 2 and a 8 in parrellel
However they will have different currents in parrellel and therefore different volumes. So this is not desireable for speakers.
Old Mar 6, 2006 | 07:12 PM
Kabs's Avatar
Kabs
im sorry... i sort of understand but not really =\
and i noticed that this amp only comes in the 2ohm setting bleh
so if i wanna wire 4 speakers who have a 4ohm and 2 subs at 2ohm to this amp it would be a bad idea?
Old Mar 6, 2006 | 07:23 PM
Racerinlsl's Avatar
Racerinlsl
kabs,
I'm assuming you're talking about a 4 channel amp? I also assume your 4 speakers are mids and/or highs? Then you have 2 subs that are 2 ohm? It's not a problem to run your highs at 4 ohms and your lows at 2 ohms....no an issue at all.
Old Mar 6, 2006 | 07:26 PM
Kabs's Avatar
Kabs
well the amp is a 5 way amp...its made up of 2 amps in 1... i dont think u can change it from 2-4ohms
my fronts and rears are 4ohms... they are some sort of concept brand 100rms max 250w...speakers
subs will be type r's at 2ohms
is that what u meant?
Old Mar 6, 2006 | 07:46 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
in order to get the most power outta your amp, you want your sub to equal the resitance of the amp.
max power transfer = (R(amp)^2)/(4 Rsub) which occurs when Ramp=Rsub.
so keep that in mind to make your sound system put out as much power as possible...
Old Mar 6, 2006 | 07:58 PM
Sean's Avatar
Sean
i tried to learn about Ohms but my brain met with too much resistance
Old Mar 6, 2006 | 08:02 PM
Kabs's Avatar
Kabs
no no i undertand that if im at 2ohms in the amp... my sub should be 2ohms too... i have that set... im just worried i wont eff my speakers up
Old Mar 7, 2006 | 08:59 AM
Inovashn's Avatar
Inovashn
i'm not sure if your going to have enough power to run those Type R's. They need to have a lot of power.
Old Mar 7, 2006 | 01:25 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Wire your subwoofer's 4 ohm coils in parrallel with each othe to get a two ohm load. JL Audio has a great document showing you how to wire various speaker impedances to each other to match a given amplifier.
If the speaker needs more than 400 watts to "run" pull them out and beat the salesmen with them until his eyes pop out because he ripped you off. If you're not pushing 110 dB and hearing loss with them at 400 watts I'd be really surprised.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
