Need 350z wiring diagram (including nav)
Specifically, I need the diagram for the wiring going to the nav door circuit board. There are is a harness plug here on the this circuit board which connects to the OEM nav brain.
I've read the posts about this and usually this plug is where the conversation ends. The plug on the nav door has 10 contacts. I understand that there is an amp or interface which connects to this plugs and acts as an interface between the door and the OEM nav-brain. But no one knows what these 10 contacts are connected to. If I could find a wiring diagram it would probably solve the problem. I may even call the dealer and see if they know.
I know the following connections are contained on the door:
Motor (2 connections)
Activation button (2 connections)
Limiting switch (2 or 3 connections)
12v (1 connection)
Ground (1 connection)
and in theory...
Output? (1 connection) - I think this signal tells the nav brain if the door is open or close or transitioning.
So that is 9-10 connections that may or may not map to the connections on the door's harness plug.
Any tips, suggestions, wiring diagrams, etc would be helpful. Me and a few online buddies may be close to figuring this out. But we just need to know what those darned harness connections are!
Thx
-Smoky
12v (1 connection)
and in theory...
Thx
-Smoky
There's some info in this thread... https://my350z.com/forum/audio-and-video/171725-wiring-color-code-guide-for-350z.html
I think I've mapped the 10 contacts on the nav door's PCB... or at least some of them...
Pin 1: None
Pin 2: Motor 12v
Pin 3: Motor Ground
Pin 4-7: None
Pin 8: Switch (marked as "Limit")
Pin 9: Switch (marked as "2")
Pin 10: Activation Button (marked as "1")
Now I just need to figure how how to use these connections with some relays to make the button do what I want!
Pin 1: None
Pin 2: Motor 12v
Pin 3: Motor Ground
Pin 4-7: None
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
