2006 Base and Sirius
Old Apr 23, 2006 | 09:13 AM
kahuba's Avatar
kahuba
Default 2006 Base and Sirius
Recently purchased both. I own the Starmate replay model and i'm very happy with it for home use. However, the FM modulator sound in the Z leaves much to be desired. Is there a way to connect an "audio" input from the head unit to the Starmate Replay? I'm trying to emulate the connection used with the home kit (using an audio connection from my home reciever) in my car. That way i can still remove the Sirius head unit when it's not in use. If I need to clarify, let me know.
Andrew
Old Apr 23, 2006 | 09:44 AM
jpm_fan's Avatar
jpm_fan
Yes, it's completely possible. Check out the install section at http://www.siriusbackstage.com for help. They make a part that will connect your FM out directly to the antenna in and it clears it up tremendously. I'm too lazy for that, so I just use the line out on the back and use the cassette adaptor.
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
